Go Back   Sprinter-Forum > Classifieds > For Sale (Sprinter vans Only)
For Sale (Sprinter vans Only) Post Sprinter Vans for sale here. Vans must be driveable, otherwise, they go to the parts section here.
Old 07-08-2019, 06:59 PM   #1
PortlandSprinterConnection
enthusiastic t1n packrat
PortlandSprinterConnection's Avatar
Default 2004 Sprinter 140 Length Conversion Van
https://photos.app.goo.gl/yic3rX16PwvwF6z69
This van belonged to a good buddy before he sold it to me and I swapped the motor. Finally done with it, read on,
140 inch length wheelbase, 250k miles.
New BFG K02 tires,
Trailer hitch with trailer brakes,
Solar with inverter and battery bank and regulator,
Genuine Esbacher D2 heater,
Led lights inside,
Fully insulated,
Bluetooth head unit,
Fantastic fan,
GDE tune
120k on Mopar reman transmission.
Recent work done
New injector seals and injector hold down bolts,
new 150 amp alternator,
new turbo,
new turbo resonator,
new cam/crank sensors,
new water pump,
new pulleys,
new thermostat,
new fan clutch,
new serpentine belt,
new transmission conductor plate,
new transmission pin connector,
all new glow plugs,
new glow plug controller.
new fuel filter,
cleaned EGR
serviced HPFP,
rear diff fluid changed,
oil changed,
transmission completely serviced,
new windshield,
replacement AC pump recently.
I'm also going to include $800 labor with PSC in the sale. If there's stuff you want done after this, we can do it.
I will be upfront on everything I see on this van with interested buyers. Reach out with any questions.
Rear differential does make more noise than it should, I can discuss that with potential buyers.
Asking $18.5k for it. The build out inside is pretty simple, but could be stripped to wood walls and redone for a good starting point for someone to build out their own. Finish carpentry isn't my thing, so I haven't messed with it at all.
Thanks.
t1n used part/repair shop
sprinter tool lending available to local portland members.
118, 2006 tall roof, 216k and counting.
PortlandSprinterConnection is offline   Reply With Quote
Old 07-15-2019, 06:37 PM   #2
Default Re: 2004 Sprinter 140 Length Conversion Van
Bumpy bump. Price drop to $17.5k
