Old 01-25-2020, 10:47 PM   #1
tbuyan
Default Binary heater
2005 3500. My heater control knob (not ATC) is an on/off switch. Full heat at the 12 o'clock position; no heat from 1 o'clock to 6 o'clock. Please point me to any existing threads that address this. I couldn't find any. Otherwise, what?
tbuyan is offline   Reply With Quote
Old 01-26-2020, 01:50 AM   #2
koenb
Default Re: Binary heater
Not sure what you mean by "not ATC", but the hot/cold selector knob (left side, red to blue color gradiant) is the automatic temp controller (ATC). All three of the knobs/selectors and the fan speed are part of the ATC. Best guess is the potentionmeter failed and you need the module repaired.
https://sprinter-source.com/forum/sh...ad.php?t=82506 This thread just came up the other day.
koenb is offline   Reply With Quote
Old 01-26-2020, 11:03 PM   #3
It can be a broken resistive element inside the knob's potentiometer.
At one end, you're having the wiper contact touch the end-point's metal attachment
Everywhere else, the failure of the element feeds the wiper the voltage of the other end.
Some people have replaced the potentiometer with a "standard" potentiometer, other people have sent the AC control unit off to one of the $125 "we fix your AC unit" places with good results.
Three vendors people have talked about: (last updated Feb 2019)
https://www.ebay.com/i/253997662372?chn=ps
https://www.autoecu.com/climate-cont...ontrol-module/
http://www.european-autowerks.com/sp...ore-wildoam-ca
Midwestdrifter (01-27-2020)
Old 01-27-2020, 07:32 PM   #4
tbuyan
My mistake. I assumed "ATC" referred an optional feature that enabled the selection of a given temp. e.g. 74, as many new vehicles have. I see now that it simply means the entire HVAC system.
Yes, I had read that thread, but the symptoms seem to be the opposite of mine.
Nonetheless, it looks like I'll be sending my panel off to one of repair services autostaretx listed.
Thanks.
Old 01-27-2020, 08:02 PM   #5
Nonetheless, it looks like I'll be sending my panel off to one of repair services ....
If you need to drive the Sprinter with the AC head unit removed, the heat will be FULL ON
(handy in the winter)
The coolant valve requires power *to close* ... if it's unpowered, it'll open and heat will flow.
Old 02-03-2020, 06:49 PM   #6
tbuyan
A few days ago it started working as it should.
So new dilemma: intermittent binary heater control.
Old 02-03-2020, 07:45 PM   #7
It could also be a wiring or power supply issue to the head unit. Rarely the valve will by sticky. You can disassemble the piston part from the solenoid coil to evaluate.
Old 02-04-2020, 05:29 AM   #8
tbuyan
Now I'm more than a little confused. My AC works fine, so what's the reference to the "head unit"?
Old 02-04-2020, 02:25 PM   #9
KISS.
Try this before going any further.
The potentiometer contacts may have a bit of corrosion.
Try twisting the knob with a bunch of gentle, but quick twist motions.
You don't want to jam stop to stop and maybe break something.
Move the knob away from the stop, give a bunch of short twists back and forth, index a bit further, give a bunch of short twists, etc. until the entire range of motion has been done.
The idea is that the quick twists will help the potentiometer wiper to rub itself clean. If it doesn't work you haven't lost anything. (As long as you don't break it.)
Old 02-04-2020, 02:27 PM   #10
If your AC works normally, then you can discount a power supply issue then. The sensor/pot on the temp knob is known to wear, so you should try APs suggestion.
