Old 01-22-2020, 06:43 PM   #31
dbeyer
dbeyer's Avatar
Default Re: Engine stops on freeway I stuck on shoulder
Even if this was the case, unplugging the connector should then allow a start.
Unplugged TCM still no start
Having trouble getting the TCM out. Any pointers?
2004 - 118" Standard Roof Cargo
Converted to Mobile Office
dbeyer is offline   Reply With Quote
Old 01-22-2020, 07:04 PM   #32
Patrick of M
2005 T1N 2500 (NA spec)
If you can't even scan the engine, why are u messing with the tcm?
U Really need to slow down and get methodical.
Your sudden engine stop points to a broken connection/wire, though a sensor failure should show up on the scanner.
In your situation i would study the wiring diagram and make sure you had 12v where you are supposed to, key off, key on, key start.
Patrick of Montreal
2005 T1N (NA spec).
The Following 5 Users Say Thank You to Patrick of M For This Useful Post:
Aqua Puttana (01-23-2020), BrennWagon (01-22-2020), dbeyer (01-23-2020), GPLYNCHBURG (01-26-2020), Midwestdrifter (01-22-2020)
Old 01-22-2020, 08:07 PM   #33
vanski
'05 Box Snow Camper
vanski's Avatar
You supplied a couple of random obd codes which COULD correlate to this thread - https://sprinter-source.com/forum/sh...ad.php?t=28842 obviously there was no documentation to success, but perhaps some nuggets?
Old 01-25-2020, 11:48 PM   #34
dbeyer
dbeyer's Avatar
Thanks Patrick
With key in #2 or #3 position
The Starter Motor Relay 12v switch supply reads 3.4 volts
The Fuel Pump Relay 12v switch supply reads 0 volts
Both relays are supplied 12 volts through splice S108 with the key in #2 or #3 position
2004 & 2005 service manual 8W-91 Connector/Ground/Splice Location
Page 8W-91-11 identification page skips S108 totally.
Anybody know where splice S108 is located, or the where 12 volt supply originates from?
S108 is not under the seat because both relay 12v supply wires go through the floor and become part of the large harness that runs to the dash behind the battery.
With the Starter Motor Relay removed, jumpers to on and the key in the start position I get the sweet sound of the starter turning the engine over.
Any ideas?
Old 01-26-2020, 02:03 AM   #35
Patrick of M
R u reading those voltages at the key switch wiring harness or at the respective relays?
Patrick of Montreal
2005 T1N (NA spec).
Old 01-26-2020, 02:25 AM   #36
vanski
'05 Box Snow Camper
vanski's Avatar
Those are some funky readings..
Any ideas?
Remind us.. when you go to start do you feel a click in the starter relay? I forget if the ecm will even allow the motor to start if the high pressure pump isn’t seeing the low pressure it needs to fire. If not, this could be your issue as you need low pressure. But that 3.4v at starter relay is just weird leading me to believe ground issues which you’re already on to.
Old 01-26-2020, 01:34 PM   #37
dbeyer
dbeyer's Avatar
Measured at Relays, switch is unplugged, felt funky, new switch arrives tomorrow.
Accessories, run, start reproduced with jumpers where the switch plugs in to the back of fuse block 1.
No Click
Old 01-26-2020, 04:58 PM   #38
Not a sprinter, but I had an ignition switch melt down on an accord once. Just suddenly stopped working. A short in the harness had overloaded the switch, melting the solder out of the pins. So if you aren't getting power through the ignition switch, you should be able to bypass. Either with a jumper, or by plugging in a spare switch outside the ignition/lock assembly? Never tried it myself.
Old 01-26-2020, 05:26 PM   #39
dbeyer
dbeyer's Avatar
Did that, with jumpers.
see my temporary starter switch.
Old 01-26-2020, 06:00 PM   #40
jrod5150
jrod5150's Avatar
Misread your original post, my appologies theres alot of back n forth going on.. no cranks without the start error on the cluster is typically the ground strap or the negative cable to firewall. Even though they look physically good they can be bad. Sometimes just grabbing that ground cable and moving it is enough to allow it to start. Being that you lost power on the freeway is something I havent experienced. In the parked no start situation I will typically have a good strong battery and a 2nd battery (jumper) I place one lead on the battery + and I attach the negative jumper lead to the strap bolt below the fuel filter.
I recently parked one and went back out a few days later to start it, no go. Long testing story short, the cluster showed “P” but the transmission cable must have not fully engaged the physical transmission shifter arm into park. Moving the shifter back and forth did the trick although this doesnt explain your dying on the freeway. Perhaps your chasing multiple
Issues
jrod5150 is online now   Reply With Quote
