Old 01-21-2020, 07:22 PM   #21
dbeyer
dbeyer's Avatar
Default Re: Engine stops on freeway I stuck on shoulder
Fuel volume regulator control circuit low
Do you have the code number for this?
P0091 & P0003
When you turn the ignition to start, does anything happen at all?
No
Does the MBII let you monitor the start process on the ECM live data? You can check to see if the start signal is reaching the ECM.
Not sure my buddy lent it to me. Control module voltage is 7.9V but doesn't change when I turn ignition to start position.
2004 - 118" Standard Roof Cargo
Converted to Mobile Office
dbeyer is offline   Reply With Quote
Old 01-21-2020, 08:46 PM   #22
Just to double check: you DID open the fuse block that is bolted on to the battery's positive terminal?
I would also highly suspect the ECM relay that is on the bottom of the steering column's fuse block:
(item (2) in this drawing)
I think you can swap it with another relay for testing (its coil may be bad, its internal contacts could be dirty)
Another area of frequent failure is where the engine's wiring harness bends behind the fuel filter. Cutting the plastic Ty-Wrap lets you "soften" the bend and massage the wiring bundle. If symptoms change after that, you may have located the problem.
good luck
Old 01-21-2020, 09:01 PM   #23
CJPJ
2008 3500 170"ext. 3.0 V6
CJPJ's Avatar
That isn't right, .. the thirteen prong transmission cable connector o-ring seal is leaking and the oil is wicking up the wires and affecting the Tcm.
.. and module connections. TCM plugs had oil on the inside of the plugs otherwise everything looked good.
https://europarts-sd.com/transmissio...g2002-2008.asp
Old 01-21-2020, 11:38 PM   #24
Patrick of M
2005 T1N 2500 (NA spec)
Fwiw the actual key switch can be a weak link. It is a mechanical switch with contact points and they can fail. Perhaps check for current flow through the key switch in its various positions. Ie 12v in, then in different key positions there will be 12v out...key switches have messed me up plenty over the years on older vehicles.
Patrick of Montreal
2005 T1N (NA spec).
Old 01-22-2020, 03:13 PM   #25
Being that "check this, try that" didn't work, it will come down to systematic troubleshooting.
There is a bunch of information contained in this thread that relates to circuit troubleshooting and schematics. It isn't just Click no start.
https://sprinter-source.com/forum/sh...ad.php?t=58993
Old 01-22-2020, 04:45 PM   #26
dbeyer
dbeyer's Avatar
[QUOTE=autostaretx;842982]Just to double check: you DID open the fuse block that is bolted on to the battery's positive terminal?
Yes inspected fuses and have 12 volts on both sides of the fuses.
Switched the relays as you suggested.
Inspected wiring harness and moved around without any change.
Old 01-22-2020, 04:48 PM   #27
Time to get down to troubleshooting in a methodical way. Test the ECM, SKREEM, and Cluster for power at there connectors. If so, move on to communication. Can the scanner connect to each of these modules. If so, move on to start sequence. Confirm ignition switch signal, SKREEM handshake, and then move on to starter. Since the unit stalled, I don't believe you will get this far. You either have a wiring fault causing the stall, or a sudden failure of the ECM (very rare).
Old 01-22-2020, 04:54 PM   #28
dbeyer
dbeyer's Avatar
thanks, I ordered the transmission cable connector.
Do you think this caused the engine to die while traveling 60 MPH on freeway and now is the cause of no starter spinning at all?
Old 01-22-2020, 04:58 PM   #29
Not likely. I have never seen a trans issue cause stalling like that, and fail to restart. The CANbus wires do run through that connector, so its possible it could prevent a start by blocking communication (not likely).
Even if this was the case, unplugging the connector should then allow a start.
Old 01-22-2020, 05:24 PM   #30
CJPJ
CJPJ's Avatar
I don't know that. The connector seal failure is common here on this forum(with oil wiking damaging the Tcm) with Mb vehicles. I'm on the third connector but corrected the leak befor the wicking. I saw a wet connector and replaced it.
Suggest watching the u-tube video, shown on the euro parts link ..how to clean and replace.
https://sprinter-source.com/forum/sh...or+leaking+oil
