Old 11-13-2019, 01:05 AM   #11
dbedy
Default Re: 2019 Sprinter Crew Build
Yes that is the RB Components tray. I bought because I did not want to start from scratch on yet another bracket. Itís a nice piece. Turns out after some head scratching I found another place to put my heater expansion tank so what was originally a place to mount a heat exchanger and tank will now hold two more batteries.
dbedy is offline   Reply With Quote
Old 11-13-2019, 01:09 AM   #12
dbedy
Update on expansion tank mount under left front bumper cover.
Old 11-13-2019, 05:40 AM   #13
wquek
@dbedy thanks for the info. Donít you already have two batteries under the vehicle? And are you adding another 2 more batteries under the hood? Following your build closely because my crew van is coming and I will also be going with the adwag 2.0 kit and RB components tray.
wquek is online now   Reply With Quote
Old 11-14-2019, 01:52 AM   #14
dbedy
Yes I do plan on adding another couple 250 amp full rivers. To much battery is never a bad thing.
The Following User Says Thank You to dbedy For This Useful Post:
wquek (11-14-2019)
Old 11-14-2019, 05:21 AM   #15
dbedy
RedArc bms 30 install completed tonight. Itís a tight fit but it fits nicely once it has been finagled into its home.
Wiring was pretty simple, and the specs are within the body upfitter guidelines. I did spring for the parts to connect the battery charger and alternator feed exactly per MB upfitter guide. Since Iím not a professional shop I donít want to have the finger pointed at me later if there is an issue.
File Type: jpg 21E2EF22-7F2E-4BA1-8344-C6BAEB18DFE8.jpg (99.9 KB, 306 views)
File Type: jpg DB777288-D0EA-4857-931E-8BEB31CF93DC.jpg (89.5 KB, 285 views)
sgrichar (11-24-2019)
Old 11-19-2019, 07:33 PM   #16
fourbeer
Did you ever find the part numbers for the aux battery relay and buss bar for the 2019?
fourbeer is offline   Reply With Quote
Old 11-21-2019, 05:50 AM   #17
dbedy
I did
Bus bar in f150/4 fuse box. A9075454100
F150/5 fuse box. A9075402605
F150/5 fuse box cover. A9075454600
Other parts needed at 2awg cable and accompanying lugs, and nuts to hold those lugs down.
You will also need fuse link N000000-006620
Old 11-21-2019, 11:24 AM   #18
fourbeer
Where did you find the parts for sale? I did a quick search but didnít find anything online that didnít look sketchy.
-4B
Old 11-21-2019, 03:41 PM   #19
dbedy
I know people are dealership averse, but I usually just go to the parts counter at my local dealership.
The guys get to know you and want to help you find the tough parts. This was a great example of that as the f150/5 fuse box part number had been superseded 3 times.
Old 11-21-2019, 06:15 PM   #20
GeorgeRa
2013 Sprinter DIY 144WB
GeorgeRa's Avatar
Nice work, how are you planning to fill your expansion tank? and why not Rixen tank with electric heater?
George.
