Old 09-19-2019, 12:20 PM   #11
dynaco1
dynaco1's Avatar
Default Re: V30 Under driver seat pics and time for a beer.....
I did the same thing: added a 6 AWG cable to the last stud in this box. Rather than placing the fuse box, I added a surface-mounted breaker to the outside of seat base with VHB tape. I grounded my circuit on the large bolt head holding the seat base to the floor. I ran both red and black cables up/down the driver side B pillar and terminated them onto a Blue Sea fuse box sitting on top of the Vancillary cab shelf.
dynaco1 is offline   Reply With Quote
Old 10-15-2019, 04:06 PM   #12
KippyDoo
Heh Heh - so, say if someone might of unplugged their passenger seat electrical clips before remembering to disconnect the battery and has a malfunction message now even though it's plugged back in. Apologies if this is covered elsewhere, but how do you clear this? Have to visit someone with a scan gauge?
KippyDoo is offline   Reply With Quote
Old 10-15-2019, 04:46 PM   #13
Notfamous
The software for the 2019 is not available for any scan tools. You will need to go to a dealership to have it cleared.
Sent from my Pixel 3 XL using Tapatalk
Notfamous is offline   Reply With Quote
The Following User Says Thank You to Notfamous For This Useful Post:
KippyDoo (10-16-2019)
Old 10-15-2019, 05:10 PM   #14
My "labeled photo" back in posting #4 is a bit incorrect.
Another thread, plus access to the VS30's fuse allocation book allowed me to correct it.
Here's the updated version:
Old 10-15-2019, 05:29 PM   #15
There are other threads on this ... assuming you're talking about the seat belt system and the "SRS" (supplemental restraint system") warning.
Sometimes the tally light will go out after a few starts ...
There are (surprisingly expensive: $230) boxes that claim to *only* clear this on multiple cars. They're not scanners, they simply emit the "clear SRS" commands.
Some of the $250 scanners can clear it on the NCV3 (Autel 808, if i recall correctly), but the group has little experience (yet) with the VS30 in this respect. The 808 does NOT claim to handle the VS30 (in fact, Autel says that it currently does not).
If you're using the dealer network to perform Service A or Service B, you might ask them to clear it then. MB's corporate policies may require that they treat it as a true "possible fault" and perform more diagnostics (read: bill an $$ hour) than you think necessary, but they'd be covering their butts in case there really was an unknown fault in the belt/squib system.
If you intend to work under the seat at all frequently, it might help to spend a (very few) $$ to buy a "jumper socket" that appears to be the seat belt to the rest of the system (it's a 2 to 5 ohm resistor that bridges the pins)... or really follow the advice of "Step 1: Disconnect Battery" for all work.
Old 10-15-2019, 06:15 PM   #16
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
What is your location? It helps to add vehicle and location to your signature to save typing every in every post.
Someone nearby may have a scanner they would be prepared to try for you. MB has tended to use the same protocol for many years so an NCV3 profile may work on a VS30.
Keith.
36,000 miles from New
Old 10-16-2019, 05:53 PM   #17
KippyDoo
Keith.
Thanks! I'm a noob here, will get caught up :) I'm Portland, OR.
Old 10-16-2019, 05:59 PM   #18
KippyDoo
Thanks! Yeah, I followed the battery disconnect rule for the 2nd seat, and hoped being disconnected might reset the codes for the first seat I was hasty with. I may reach out to my local stealership and ask if they can just clear this code and see what comes back from them, I just shot icarsoft and email asking about compatibility of their scanner and timeframe, tried with a friends older one and no luck.
Old 10-16-2019, 06:00 PM   #19
KippyDoo
Thanks, yeah, I tried with a friends older icarsoft scanner with no luck, shot an email to them asking when they may expect to have the 2019 added, we'll see what comes back.
Old 10-23-2019, 04:12 AM   #20
skivo
$38 bucks reset at dealer. Same happened to me.
skivo is offline   Reply With Quote
The Following User Says Thank You to skivo For This Useful Post:
KippyDoo (10-23-2019)
