Old 08-25-2019, 06:59 PM   #21
Boxster1971
2012 Sprinter 3500 Ext
Boxster1971's Avatar
Default Re: EV2, 2019 4x4
Grant - congratulations on the move and the new shop!
-- Mike
Boxster1971 is online now   Reply With Quote
The Following User Says Thank You to Boxster1971 For This Useful Post:
grantwilson (08-25-2019)
Old 08-25-2019, 09:14 PM   #22
Wyuna
good luck and congrats with the new shop and moving back home.
it looks like an awesome workshop, and that extra set of hands will be helpful
Wyuna is offline   Reply With Quote
Old 08-26-2019, 02:50 AM   #23
familytruckster11
sweet rig and appreciate the pics.
I just got my 2019 170 4x4. I plan on using a Goal Zero Yeti 1400 as well (just got one on sale at REI). I have a few questions. I have a factory aux battery. I do not see the aux battery bus under the driver seat. Do you have any pictures of that? I am going to wire the yeti 1400 to the Goal Zero Link module to charge it via the EC8 cable https://www.goalzero.com/shop/cords-...ring-terminal/
I am also installing the adventure wagon kit. I figure my total amps worst case with Dometic CFX75, 2 fans and espar D2 is ~20 Amps.
I planned on wiring from Goal Zero to Adventure wagon fuse box with the 12V MAX CURRENT CABLE by Goal Zero
https://www.goalzero.com/shop/cords-...current-cable/
and https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Anderson to terminal rings.
SO.....Alternator charges AGM batteries > AGM Batteries charge Yeti via link (isolator) > Yeti powers everything
do you see any issues with this plan?
I will never be staying anywhere longer than 2 days without starting the engine so I figure I would try to skip solar for now and add that based on usage of the yeti.
familytruckster11 is offline   Reply With Quote
Old 08-26-2019, 04:26 AM   #24
downunder
Well done and good luck with it all Grant.
Like everything that you put up by the way.
Hey, ARB kicked off solely in a garage a long time ago.....
downunder is offline   Reply With Quote
Old 08-26-2019, 08:04 PM   #25
grantwilson
FreedomVanGo
grantwilson's Avatar
thats how i do it.
I find a yeti tank is a good addition as well for most people. or just go with the 3000 right away.
I just use the max current cable to the blue sea fuse box and go
2019 Built 4x4 for sale
2018 Built 4x4 for sale
FreedomVanGo - Jacksonville Florida
The ONLY Certified Adventure Wagon dealer and installer in the SouthEast
Authorized Dealer for Dometic, Ripplewear, Tern Overland, Van Compass and more!
www.freedomvango.com
www.youtube.com/GrantWilsonFL
www.Instagram.com/FreedomVanGo
grantwilson is offline   Reply With Quote
Old 08-26-2019, 11:10 PM   #26
familytruckster11
Originally Posted by grantwilson View Post
thats how i do it.
KICK ASS. Thank you for the response!
I was 80% sold on the 3000 but REI only had the 1400 on sale (20% off) so I had to try it. If the fridge won't last days in it then I will return/sell/swap.
SO the connection under driver seat is pretty straight forward? I will yank my seats soon. D2 heater just arrived today too!
Old 09-17-2019, 10:50 PM   #27
familytruckster11
Hey Grant, Have you ever ran the adventure wagon electrical harness from the passenger to the driver side OVER the headliner? Thoughts?
Old 09-18-2019, 01:00 AM   #28
InspiredVan
We do it on our AdvWagon installs. No problem other than sometimes you need to loosen the drivers seat base to run the extra bundle of wires into the seat base. And yes, torque the base back down after you've run the bundle thru....
Sent from my SM-G892A using Tapatalk
InspiredVan is offline   Reply With Quote
Old 09-18-2019, 01:56 AM   #29
GSWatson
2013 144
GSWatson's Avatar
I think heís asking about not going through the regular channel between the seats on the floor, but up and over the headliner. Which I donít see why one would choose. Thatís probably 15 to 20 feet of wire, and the corresponding voltage drop, plus expense and hassle.
Cheers,
Greg
Old 09-18-2019, 02:42 AM   #30
InspiredVan
actually it is about the same distance from where the adwag wire harness branches off in the ceiling. its routed along the front rib directly behind the rear edge of the headliner and down the drivers side b-pillar. its easier/quicker than ripping up the entire floor assembly to access the very crowded wire chase. can you run it the other way? sure. there's plenty of ways to skin a cat.... personally I'm a fan of K.I.S
S.
