Old 08-21-2019, 09:24 PM   #21
sulkorp
Default Re: DD/Digital Lab/Camper
The sliding door protective rubber piece started to lose its secure connection to the glass. While driving it would flop in the wind. Luckily it didn't come off anytime I was on the highway.
After putting it back on with force, it would still come off shortly afterwards.
The solution that has been working in rain and heat is to use a small piece of Snot Tap at the top. Snot tape is what I have known it to be called within the film industry forever, yet for this post I just found out it is actually "Clear Butyl Tape" It is available online, and probably also at your local film expendables shop.
Attached are a photo of the style of tape. It does stick out a little bit if I get close, yet more than acceptable.
sulkorp is offline   Reply With Quote
Old 08-27-2019, 04:47 PM   #22
sulkorp
Here are the batteries that I will be using in the interim of a full setup. I have another unit which is fused.
My current plans are to take them out and charge them when they die.
I should also be able to use my Noico Genius charger connected via a cigarette socket inverter while driving. This could allow me to get a top up on the charge when driving.
My fan will be connected to this, and any other accessories I'd like to run ie USB charging.
Old 09-04-2019, 11:57 PM   #23
PeterW
Hey sulkorp, in post #6 you mention:
"It is clear that they didn't address the exterior trim issue, as the clips are not weather sealed."
Is the first photo in that post showing a spot where it's leaked? Have you tried pulling the panels and sealing them?
(see my thread asking about this and the supposed new fasteners which now seem to cost a lot - https://sprinter-source.com/forum/sh...ad.php?t=79145 )
PeterW is offline   Reply With Quote
Old 09-06-2019, 01:36 AM   #24
Notfamous
Conversion is almost done! I went with the roll-a-ramp. Great recommendation! I still need to make wheel well cabinets to protect the battery in the back and create a charging station. Then do some type of basic grip stowage on the passenger side. It's coming along though.
Sent from my Pixel 3 XL using Tapatalk
Notfamous is offline   Reply With Quote
Old 09-06-2019, 08:07 PM   #25
sulkorp
Not showing any leakage! Just commenting on the visuals.
I haven't pulled mine apart in a while to see if anything has changed.
I am very happy to hear they have new fasteners! I really did not enjoy the idea of sealing it
Old 09-09-2019, 08:06 PM   #26
sulkorp
Looks great! Much further along that my build, and looks great!
Are you going to be doing a build thread?
What kind of battery source are you using&ah ?
Old 09-09-2019, 08:15 PM   #27
Notfamous
I haven't thought of doing a right up. It's an adventure wagon kit with my electrical harness. I'm using a goal zero 1400 battery behind the rear driver side wheel well. That's probably the only semi-newer thing I'm doing since most previous builds are doing under the driver or passenger seat power. I will be building storage cabinets on the wheel wells and may do a write-up on that. I'm just glad you mentioned the roll-a-ramps bc my folding ones were taking up so much room.
Old 12-06-2019, 12:57 AM   #28
HarryN
Any additional insights on the wool insulation ? Pro / con?
Thinking about Havelock.
Old 12-07-2019, 12:41 AM   #29
sulkorp
I really enjoy working with the wool insulation. It is very easy to stuff, and also easy to take out if you need to re-do anything. Cuts down on road noise quite a bit.
With proper ventilation the van does keep cool on the summer. In colder weather it helps too.
I installed a Maxxair fan and during the summer with the fan it was great.
I don't have an Espar yet, so now that the weather is in the negatives overnight it is still cold.
While driving and heat on, it does keep it in for a while afterwards.
I imagine Havelock is similiar, as there wasn't a local vendor for it I went with a local option.
Old 01-03-2020, 02:18 PM   #30
sulkorp
I haven't updated in a while, though there I am still chipping away at the van.
Installed a Maxxair fan in the summer, and it made a ton of difference.
I followed the instructions from ourkaravan, and it mostly went well. I did make a modification, as I had Hein's interior expanded pvc supports, yet didn't install them when I did the fan install. I went straight into the sheet metal, yet wasn't happy with that.
I ended up cutting the pvc down to size, pre-drilling holes for where the screws came down. Put Dicor Lap-Sealant inside the holes, then applied butyl to the strips, then put them onto the ceiling.
Next I made a square wood support bracket, which I used two stands to hold the pvc tight to the ceiling for a few days. Counter sunk some 1/4-20, and bolted them into the stands
I haven't had any problems with this setup so far, and I have installed the trim into the pvc without issues.
