Go Back   Sprinter-Forum > General Forums > The Competition
The Competition Discussion of other vehicles similar to the Sprinter; Transit, Promaster, etc.
SubForum: Write-Ups
Old 11-17-2017, 03:41 PM   #1
cargovanconversion
Arrow ETFE Flexible Solar Panel Install on Ford Transit
It was finally time to install the flexible panels from Link Solar. I chose the 135W version as its length (59.5 inch), did fit the width of the Ford Transit's roof exactly. That meant optimal use of the roof area. Without a roof vent you'll be able to install 5 panels (675W), four (540W) if you have a roof vent installed and three (405W) like me, if you eliminate the front panel, because it is readily visible from the street. An Extended version of the Transit will support up to 6 panels or a whopping 810 watts.
video here
I use 3M's VHB tape 5952 to create a leak-proof connection to the roof; the panels are virtually invisible from the street, except for the MC4 connectors.
You can read more on CargoVanConversion.com http://cargovanconversion.com/10389/...l-installation
video here
cargovanconversion is offline   Reply With Quote
The Following User Says Thank You to cargovanconversion For This Useful Post:
dray2009 (02-22-2018)
Old 11-25-2017, 05:36 PM   #2
cargovanconversion
Default Re: ETFE Flexible Solar Panel Install on Ford Transit
The panels are now installed, the wiring laid on the roof; today I am placing the cable gland on the roof and pull an 8AWG MC4 cable through the roof.
View the video here
Old 12-08-2017, 03:08 PM   #3
cargovanconversion
I have finished the installation of my ETFE Flexible solar panels on my Ford Transit.
View the last video here
Van Williams
Old 09-08-2019, 05:55 PM   #4
dirksgoat
Van Williams
Has the system performed well?
dirksgoat is offline   Reply With Quote
Old 09-15-2019, 06:02 AM   #5
monoloco
Why the concern of them being seen from the street?
monoloco is offline   Reply With Quote
Old 09-15-2019, 05:27 PM   #6
Possibly a mild attempt at being a "stealth" camper...
(there are many threads by people attempting to be less-obviously an "RV")
