Old 01-20-2020, 07:07 PM   #1
kfo
Default Yet another subfloor question: Insulation Compression, Subfloor Rigidity, Noise
Hi All,
I completed my subfloor months ago, and am unfortunately considering ripping it out and replacing. Looking for advice on addressing some issues I have with my first iteration.
My subfloor is 1x2 pine slats, both horizontal and vertical, creating a lattice structure at an elevation 3/4 above the highest ribs. These pieces are adhered to the van floor with marine adhesive. Then, the voids were filled with standard Thinsulate SML 600 (non-compressible), and the stud/lattice structure was skinned with 1/2 BB primed ply.
Overall, the floor is extremely level and solid. There are no low spots, and I can bolt through the body pretty much where I choose without the floor deflecting much (close ribs, pretty rigid BB ply tied down with *many screws into the studs.
But-every time I walk on it, it makes slight creaks/noise. It sounds like an old hardwood floor in a house. Im noise sensitive and it annoys me a ton. I think the adhesive perhaps is not a great solution when the body flexes, resulting in glue failure. Then there is independent movement between the studs and metal floor, and the movement creates noise.
I am debating mini cell or the other kind of Thinsulate (au400 I believe); filling the low ribs with minicell, then a single layer, then 3/4 or 1/2 BB ply and bolting it down. For those of who have done this: is it *solid? Does the floor feel rigid like a slab, or is there give? Do I have to block areas where I will bolt cabinetry/batteries etc, and the doorways so the minicell doesnt compress? I want a solid floor like I have now, but without the moving pieces/noise.
I know this topic has been discussed at length, but Im wondering about specifically noise/compression properties.
kfo is offline   Reply With Quote
Old 01-20-2020, 07:45 PM   #2
Montucky
Default Re: Yet another subfloor question: Insulation Compression, Subfloor Rigidity, Noise
I used 3/4" BB for the floor. 3 sheets, biscuit joined and glued together at the seams. This is laid on top of a full sheet covering of 1/4" minicell foam from Hein. The rib recesses are filled in with strips of the same minicell but in .300 thick. The floor is bomber and never makes any noise. Very solid and very happy with the outcome.
Montucky is offline   Reply With Quote
Old 01-20-2020, 08:18 PM   #3
kfo
Good to hear. My 2019 has varying rib depths-did your van have different depth ribs as well? Did you double up?
When you bolt the stack down, does the minicell compress to a point and then its solid/no deflection beyond that point? Or does the minicell have very little compression capacity even before bolting the floor down?
Old 01-20-2020, 08:28 PM   #4
Shawn182
Marie adhesive inherently has flex built into it vs construction adhesive which can become brittle and break down line you describe. Boats move non stop...houses do not (hopefully).
Did you put marine adhesive between stingers and plywood as well as between ply sheets? That is the location that most floors squeak.
While you may not feel it, 1/2" is very flexible ply in a flooring application.
I have wood stringers to floor using marine adhesive then 3/4" ply screwed down. Zero squeaks.
Anywhere you have wood to wood or wood to metal contact throw down a bead of adhesive. That may be a cheaper solution than tearing he whole thing out and stating over.
Shawn182 is offline   Reply With Quote
Old 01-20-2020, 08:48 PM   #5
Montucky
When you bolt the stack down, does the minicell compress to a point and then it’s solid/no deflection beyond that point? Or does the minicell have very little compression capacity even before bolting the floor down?
I don't recall doubling up on the strips that I put into the recesses between the ribs, but it can't hurt. You just want to be sure that the foam doesn't protrude above the plane of the top of the ribs.
The support of the minicell is perfect IMO. It doesn't feel squishy at all. Although the foam seems like it might squish under the floor, we're dealing with distributed loads on the foam, under a very rigid layer of 3/4" ply... so in reality the 3/4" plywood is supported about as well as it would be if it we laid directly on top of a rigid underlayment.
I used the factory fastener locations to bolt the floor down, and I didn't torque mine down too tight (until I squished all the foam). I tightened the floor bolts until the plywood was secured tight to the foam, and left it like that. I obviously don't want it flopping around, but it doesn't need to be torqued down crazy tight. I have L track in the back which helps pinch the floor down tight, and I did add a single fastener from the underside to secure the area immediately behind the passenger seat.
The Following User Says Thank You to Montucky For This Useful Post:
kfo (01-22-2020)
Old 01-21-2020, 01:45 AM   #6
gltrimble
Yes the floor grooves vary in depth. I believe the 3 deeper grooves are 1/2 deep while the remainder are about 1/4-3/8. I also filled the grooves with mini-cell foam flush with the top of the sheet metal ribs. I then installed the OEM rubber floor from my crew van over the mini-cell. My factory 3/8 composite wood floor was reinforced at select locations with 1/2 Baltic birch, the remaining voids were filled with 1/2 poly-iso, before being bolted down. No squeaks at all. More details on my build thread Baby Shamu.
gltrimble is offline   Reply With Quote
The Following User Says Thank You to gltrimble For This Useful Post:
kfo (01-22-2020)
Old 01-24-2020, 11:02 PM   #7
kfo
I used the factory fastener locations to bolt the floor down, and I didn't torque mine down too tight (until I squished all the foam).\
Quick question-did you use contact adhesive for the final sheet of Minicell? If so, was it in a few places just to tack it in place, or full coverage-spraying the floor fully and then the top sheets, and adhering them completely? Thanks.
Old 01-26-2020, 12:15 AM   #8
Montucky
I didn't use any adhesive. It's just floating. I did tape the seams using gaffer tape so that it held the pieces together as one continuous piece. You may be able to see the tape in the photos.
I don't think you'd have any problems if you hit a few spots with adhesive to hold the layers in place while you install the floor. I dropped my floor in as one piece, so nothing really had a chance to move.
kfo (01-26-2020)
Old 01-26-2020, 07:58 PM   #9
HarryN
In older homes they used solid wood joists and you are right - they do squeak. The question is - why do they make noise? The reading that I did indicated that it is from the wood moving up and down the shaft of the screw, and the wood joints moving relative to each other.
Some builders use laminated / engineered joists to make the boards more consistent - and frankly also to hold fasteners better.
We had a few rooms that had floors that made noise. Obviously it would be difficult to replace the joists in our house, so I added a LOT of screws to the floor and put down the carpet again. I also added some talc powder as a lubricant - not sure if that helped or not, but the noise level is much less.
I suspect that the pine is just not hard and strong enough to really hold the screws well. Laminated wood such as good quality baltic birch is rather dramatically harder and holds fasteners better than pine.
Especially if you get the 13 laminations / 18mm thick, it is super dense and holds screws pretty well. You almost have to drill a pilot hole before it will accept a screw.
Power systems for conversion vans and emergency preparedness.
https://wirlnet-inc.square.site
