Engineer In Residence
I have been considering a DIY LiFe battery pack for my van. Something in the 200-400AH range @ 12V.
Quality cells seem to be available from CALB, Fortune (frey) etc. A user over on ExPo recently ordered 16 100ah cells factory direct from Frey. Only $1600 delivered, and came with factory test reports.
https://expeditionportal.com/forum/...tteries-vs-drop-in-replacements.198005/page-4
I have an existing electrical system consisting of Outback inverter, Solar CC, Mate, and FlexnetDC battery monitor. This system is not super configurable (unlike Victron), but it can be programmed to charge lithium batteries suitably.
My major needs to build a diy pack, are monitoring system with cell voltage and temp monitoring. One that can trigger a pack disconnect. Likely a gigavac latching relay, or their high efficiency NO relays (0.3A at 12VDC).
Anyone have a suggestion for a reasonably priced BMS that can provide temp and voltage disconnect? I don't need remote monitoring or a fancy screen, just a last case safety system.
Balancing would be nice, but is not required. If I feel its necessary, one of these 4s balance boards would do the trick.
The Orion Jr BMS would meet my needs, but is pretty pricey at ~$550. It has lots of functionality that I don't need. Regardless the BMS must have programmable setpoints. I could rely on the active balance boards, and just use a pack level disconnect, but that creates a single failure point that is not protected.
A pack heater would just be a ~100w silicone heating pad with electronic standalone thermostat, and mechanical overtemp protection.
This would yield a pack with much higher peak current than the drop-ins with solid state relays. Though the trojan units with normal relays would be about the same. Those are around 1k per 100AH. $1600+$700 in materials would yield a 400AH pack with much higher rates. If a cell fails, it can be replaced without trashing the whole pack.
The primary goal is for this to be the last pack this van will ever need. I don't want to be dependent on some untested (though likely reliable) electronics buried in a 1000$ battery. I don't want the complexity and issues that come from having 2-4 parallel BMS. The Tesla modules are nice, but I don't want to completely rework my electrical system for 24VDC.
