march
Did you know there are hidden surprises in your Pleasureway? I have a 2008 Ascent and found a factory power source under the seat base cover near the floor by the hand break. I exposed the power source permanently. If you do this you will need to remove the seat to expose it properly.There is a factory cargo light in the rear above the doors under the panel covering the gap between the rear door frame and the rear cupboard. I am planning to move the rear light down so I have a light in the rear - there isn't one there now so moving it will be useful.
