Old 12-25-2009, 05:18 AM   #1
sail_ski
Default LP tank mount on under carriage
Looking for info on LP tank mounted to under carriage on 2007 long body. Where is the best place to mount & how is it protected
Bob
sail_ski is offline   Reply With Quote
Old 12-25-2009, 12:08 PM   #2
Hit The Road Jack
2006 Roadhouse Sprinter
Hit The Road Jack's Avatar
Default Re: LP tank mount on under carriage
Bob
IMO, drivers side, behind fuel tank. Keep in mind a permanently mounted under chassis LP tank will not be refillable @affordable filling stations such as BJ's Wholesale Club...
I keep a 20lb tank inside my hitch mounted generator box...
... Hit The Road Jack...
Hit The Road Jack is offline   Reply With Quote
Old 12-25-2009, 03:38 PM   #3
Mrdi
Mrdi's Avatar
If it were accessible from the side would it be filable from a regular establishment?
New laws?
Mrdi
2008,2500, 144 Hi Cargo
Surf City USA,
Southern California
Old 12-26-2009, 05:11 PM   #4
qualityair
'09 144" Cargo
I maybe wrong, but for a concealed tank, at the fill port must be an ASME stamp listing tank info like ... size and age etc.
qualityair is offline   Reply With Quote
Old 12-26-2009, 05:52 PM   #5
ches
ches's Avatar
Are there any regulations about carrying LP tanks on the rear of a vehicle? I am thinking about being rear ended. Thanks
ches is offline   Reply With Quote
Old 12-27-2009, 10:07 PM   #6
sail_ski
I should have clarified that tank or tanks will be removable.
I have found the NFPA Code reference NFPA 1192 November 2001 ROP which references RV'S also there are articles in the NFPA code section 58. Now I have to read & will post what I find on this thread.
Old 12-28-2009, 01:05 AM   #7
d_bertko
Why do you want a removable underside tank?
I don't need a propane supply inside my diesel-heated DIY with an all-electric kitchen. But we often bring an extensive outdoor kitchen with a bbq and oversize camp stove that run on propane. I installed a plumber's propane locker inside my van and that gives me the option to bring along a 20 to 40 lb propane tank. Works great. The 20lb bbq tank I use leaves room inside the padlocked metal locker for laptop, camera or other valuables storage.
Old 12-28-2009, 01:06 AM   #8
qualityair
'09 144" Cargo
http://www.phmsa.dot.gov/portal/site...gnextfmt=print
This may help you.
Charles
Old 12-28-2009, 01:07 AM   #9
rvdriverca
On my Pleasure way 2006 158" Sprinter motor home, the LP tank is mounted under neath the driver side behind the fuel tank. There is a small door to refill the tank from the outside. There is a switch to shut of the solenoid valve that feeds the LP to the inside for the fridge and stove and heater from this tank.
rvdriverca is offline   Reply With Quote
