Old 07-01-2019, 07:20 PM   #1
Wessels69p
Wade
Default Rooftop AC option with OEM model
Hello all,
I have a 2009 passenger van that I have been converting. It has a factory rear rooftop ac unit. I'd like to have the ability to run the ac while parked. I am assuming this means I need to get a purpose built RV style AC unit but I thought I would check this group before doing that. Is there a way to retrofit/modify the unit to work off a generator? Those long hot days at the racetrack are hard on the family/kids. :)
thanks, WW
Wade
2009 Sprinter 2500 170" WB (moto/bicycle hauler and sleeper)
Wessels69p is offline   Reply With Quote
Old 07-01-2019, 10:14 PM   #2
hein
Van Guru
Default Re: Rooftop AC option with OEM model
I don't think it is feasible to rework the OEM AC to run off shorepower since the compressor is run by the engine via a belt. Replacing that with a electric compressor would be an expensive proposition. If you decide to go with an RV style rooftop AC then we can provide a CNC cut plate that will cover and seal the large hole needed by the factory AC and has a 14x14 hole for the aftermarket unit. We also make a cover plate without the 14x14 hole if you want to just cover it and then install the new unit in a different location. That could open up more space for solar panels.
All the best,
Hein
DIYvan
541 490 5098
2010 MB 3500 RV conversion.
Old 07-01-2019, 11:48 PM   #3
Its just not a cost or labor reasonable option. It depends on climate, but you may need as much at 15k btu in hot humid areas in direct sun, especially with lots of windows.
