Old 08-24-2016, 11:39 PM   #1
EBH
Default fuse removal
The 12 volt outlet on the bottom of the centre counsel failed ( NO POWER) on my 2007 van.
I checked the manual and it shows #25, 25 amp in main fuse box, I found it no problem, however
it has a very different type of fuse.
Tried to remove it but no luck.
Did not want to break anything, so how does one go about removing it.
Any help would be appreciated.
Ed
EBH is offline   Reply With Quote
Old 08-25-2016, 12:19 AM   #2
sailquik
sailquik's Avatar
Default Re: fuse removal
Ed,
It just pulls straight out like the other fuses but it takes a bit more force.
It's called a Maxifuse as it has 2 elements inside.
You can find 20 amp and 30 amp maxi fuses at your local parts store, but I had to purchase
the 25 amp from the Mercedes dealer's parts counter.
Here's something about this fuse, with photos:
http://sprinter-source.com/forum/showthread.php?t=14135
Hope this helps,
Roger
2019 Sprinter 519/907/VS30 series (3500 DRW) 170"/4325 mm wb Hi Top Short Back
OM-642 3.0 liter V6/7G-Tronic, 7 Speed manually shift-able transmission.
OEM back up camera, LED light package, fog lamps,
Had 2014 516 OM-651 I4/7G-Tronic|2010 NCV3 519/3500/144|2011 & 2012 NCV3 519/3500 170
2006 T1N 3500/158
Old 08-25-2016, 11:18 AM   #3
EBH
Thanks Sailquik!
I tried by using a needle nose plier and no luck.
It appears to have a cover/lock around it.
So I won't get upset, I'll get a bigger hammer.
Cheers
Ed
Old 08-25-2016, 11:39 AM   #4
Tooth Fairy
Away with the fairies.
First problem is, why did it blow?
Current ride
Ford Territory reliability, full time 4x4, 6 speed auto, 2.7L V6 Diesel Durotech, 8.5 litres per 100 kilometers.
Previous vehicles.
2002 Ford F250 Super Duty (excellent for 13 years from new)
2004 Mercedes T1N 316 (secondhand ex ambulance)
2011 Mercedes Vito 115 (secondhand ex police camera vehicle)
2011 Mercedes NCV3 316 cab chassis 4x4 (secondhand absolute piece of sh!t, I hope it burns in hell)
Tooth Fairy is offline   Reply With Quote
Old 08-26-2016, 11:47 AM   #5
EBH
Good question.
Not sure unless some thing shorted it out some where.
I will give it a try and should it blow again then I will go into why it is blowing.
I have done a continuity check on the 12 volt outlet and all seems well, ground checks out ok, positive + to negative- no continuity. ( which tell me there is no dead short)
This did happen after I forgot to shut the flasher off and went to see a show and two hours later they where still going, not sure if there is a connection there or not.
I have a 6000 kms trip to do and then I'll get into the heart of it.
Thanks for your input!
Ed
