Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Airstream > Interstate
Old 05-08-2019, 01:43 AM   #1
mything2
mything2's Avatar
Default Fog light switch replacement help
I have a 2007 Airstream Interstate and I believe I have a bad fog light switch but cannot see a way to remove and replace the switch without first taking apart the dash components.
To back up a bit, my conclusion about a bad switch is due to no power on the circuit feed to the fog lights. Iíve checked the fuse panel and itís OK so Iím ASSuming itís the switch.
Any ideas and/or procedures appreciated.
Dan
Dan Ferguson
mything2 is offline   Reply With Quote
Old 05-08-2019, 08:58 AM   #2
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: Fog light switch replacement help
Dan,
The fog light switch will almost certainly be the standard MB fit so you would do better asking on the T1N sub forum (I note your 2007 AI is actually on a 2006 chassis).
Keith.
36,000 miles from New
mything2 (06-22-2019)
Old 05-08-2019, 07:21 PM   #3
The fog lamp switch on a T1N feeds a relay. If the relay coil has failed, you'd also see no fog light action.
The switch is a SPST (single pole, single throw) non-momentary (i.e. when switched ON, it stays on), with a light.
In the 2006 service manual, the switch is shown on page 8w-50-9, and the relay and lamps on page 8w-50-10
The switch/relay and the lamps have separate fuses.
Old 06-22-2019, 03:16 PM   #4
mything2
mything2's Avatar
Dick- TUVM for your reply. Although my RV is a 2006 model year Sprinter, itís a 2007 Airstream buildout and the fog lights were added during the RV conversion so thereís another fuse location...thatís what Iím trying to locate....itís somewhere in the engine bay Iím told by a local Sprinter mechanic. Any idea how I can locate it?
Dan
Dan Ferguson
