Old 02-17-2019, 06:46 PM   #1
Dan Rosenthal
Default Wiper fuse #6 keeps blowing
Iím new to this thread but Iím blowing fuse # 6. I disconnected wiper power and the directionals work and it doesnít blow a fuse. I disconnected wiper linkage from motor and it still blows #6 fuse. Iím not really mechanically inclined but Iím guessing itís either a short or I need to replace multi functional system? The hazard lights are working. Thanks for your help!
Dan Rosenthal is offline   Reply With Quote
Old 02-17-2019, 07:08 PM   #2
NelsonSprinter
Former Nelson BC Sprinter
NelsonSprinter's Avatar
Default Re: Wiper fuse #6 keeps blowing
What model yr do you have?
Check for worn wires to wiper motor or corroded connections, fuse box short etc or replace motor if they are good.
Previous owner of '02 FL 2500 140WB Cargo door windows, 15" Alloys, LT235/75R15-E Nokian Rotiivas, Nokian Hakka C studded winters, Curt 4 hitch, 3.72 rear with 30MPG Cdn GDE ECO Tuned. . .
I am NOT a MECHANIC, I just play one online.
'02-'03 Fuel filter leak fix http://sprinter-source.com/forum/sho...ix+fuel+filter
15" tire options http://sprinter-source.com/forum/sho...t=tire+options
NelsonSprinter is offline   Reply With Quote
Old 02-17-2019, 08:07 PM   #3
autostaretx's Avatar
Since it's fuse #6, it's probably a T1N ...
As Vic said, it could be the switch, but it could also be the Fuse Box itself (a conducting bar loose, or the 'intermittent' circuitry), it could be the relay or relay socket (at the bottom of the fuse box), it could be the wiper motor.
I'd start by unplugging the relay, then the motor to see if the fuse still blows... (that's two tests, put the relay back in for the motor test)
The wiring involved is drawn in section 8W-53 of the 2006 service manual.
