Old 01-09-2019, 08:02 AM   #1
cliff1654
Default Hot water
Hi all.
Im looking to install heating and hot water into my van (for shower and sink). I will probably go with a diesel air heater but im not sure what to do with the water so looking for ideas about what others have done. It needs to be able to run without a 240v hook up where possible. I like the idea of the Webasto diesel water/air heater, buts its super expensive. I wanted to avoid the whole gas thing if possible as it takes up a lot of room. I have a solar system (380w of panels and 240ah of batteries. Is there a 12v electrical water heater that i could use with my current set up?
Cheers
cliff1654 is offline   Reply With Quote
Old 01-09-2019, 08:10 AM   #2
Aussie 2002 4x4
Aussie 2002 4x4's Avatar
Default Re: Hot water
look into the Duoetto Mk2 Gen 3 (the latest model has an adjustable thermostat on both 240v and 12v). It's only 10 litres but you can heat up to about 70 degrees (so when you mix with your cold you end up with a fair amount) ... or only heat up to the temp you'll use
It's 25 amps on 12v so it drains a bit...but it retains heat well
Aussie 2002 4x4 is offline   Reply With Quote
The Following User Says Thank You to Aussie 2002 4x4 For This Useful Post:
cliff1654 (01-09-2019)
Old 01-10-2019, 01:43 AM   #3
PeterInSa
We have a Suburban Hot Water unit (14L and $800+) in both our Caravan and Sprinter Campervan to me they are the best of the RV units.
A mate just purchased one of the items below ($132) or similar to wash down his Bar b Q in the yard or when in the bush, being stand along ie not installed in the RV gets rid of the heat easily otherwise you need to have air access to the heater via a hole in the side wall of your sprinter, to me ditto for the Duoetto MK2 above.
https://www.ebay.com.au/itm/MAXKON-G....c100677.m4598
PeterInSa is offline   Reply With Quote
The Following User Says Thank You to PeterInSa For This Useful Post:
cliff1654 (01-10-2019)
Old 01-10-2019, 01:52 AM   #4
owner
owner's Avatar
I have the mk1 duoetto and its been great for the past few years. I don't use the 12V though. I use 240V or an engine heat exchanger to fill it.
owner is online now   Reply With Quote
The Following User Says Thank You to owner For This Useful Post:
Old 01-10-2019, 03:24 AM   #5
MotoXPress
https://www.amazon.com/Gasland-1-58G...MMY6313PMQ5J6D
Would this work in a bumper mounted carrier (Aluminess) with a propane and water tank?
MotoXPress is offline   Reply With Quote
The Following User Says Thank You to MotoXPress For This Useful Post:
Old 01-10-2019, 04:09 AM   #6
mcguyver
This one appears to be popular with 4wd set.
https://www.joolca.com.au/hottap?gcl...iABEgLkx_D_BwE
2012 316 MWB 4WD
mcguyver is online now   Reply With Quote
The Following User Says Thank You to mcguyver For This Useful Post:
Old 01-10-2019, 01:16 PM   #7
Graphite Dave
Dave Orton
First question is do you need hot water at the sink. If not then supplying warm (not hot) water just for a shower is easier to accomplish.
https://sprinter-source.com/forum/sh...&postcount=159
The Following 3 Users Say Thank You to Graphite Dave For This Useful Post:
cliff1654 (01-10-2019), nada (01-15-2019), Skippy and Emu (01-13-2019)
Old 01-13-2019, 08:48 AM   #8
Skippy and Emu
Skippy and Emu's Avatar
Graphite, love your setup. Probably would do that myself, but went down another path, several months ago.
http://copperheadwater.com.au
I like the Copperhead 'cos it's Australian, works on 24v ( solar ) so, no inverter required, and is digital, and portable etc. Similar benefits to yours.
Pictures are from last winter, when I was testing and setting it up. It's heatwave temperatures where I am now.
So, have removed it from the Sprinter.
When reinstalled, and using again, I need to get a new esky ( cooler ) as the current one has metal fittings, and the steam condenses on them, and drips water.
2003 313cdi MWB, High Roof, Manual, ECB Bullbar, Windows all around, Rear Aircon, Swivel Passenger seat, 580 watts solar, 150 amp alternator, Fiamma f45s, Carr Mega Step, Chinese 2kw diesel heater, 225000 kms.
Skippy and Emu is offline   Reply With Quote
The Following User Says Thank You to Skippy and Emu For This Useful Post:
nada (01-15-2019)
Old 01-13-2019, 01:23 PM   #9
Graphite Dave
Dave Orton
Same thing with different parts.
Old 05-17-2019, 12:59 PM   #10
bobmac
Originally Posted by cliff1654 View Post
Hi all.
I'm looking to install heating and hot water into my van (for shower and sink). I will probably go with a diesel air heater but i'm not sure what to do with the water so looking for ideas about what others have done. It needs to be able to run without a 240v hook up where possible. I like the idea of the Webasto diesel water/air heater, buts its super expensive. I wanted to avoid the whole gas thing if possible as it takes up a lot of room. I have a solar system (380w of panels and 240ah of batteries. Is there a 12v electrical water heater that i could use with my current set up?
Cheers
I used a marine hot water heater in my long and tall Sprinters in New England and Queensland. They were not suitable for the MWB 4x4 because of their large size.
https://www.ebay.com.au/p/Attwood-Ma...d=323379949723
For the smaller Sprinter I've used a 4-1/2 kg propane bottle with a loop of 16 mm aluminum ex-air con tubing for the heat exchanger and use the existing ambo rear air con heater lines for heating water while I drive. A temperature regulating valve is necessary for shower water as the engine water temp is too high. I supply the tank from a 20 litre Jerry can which is easy to remove for filling and pump into the propane tank. An air cushion in the tank allows for expansion and stored water pressure. The regulator feeds a wand type sprayer with integral shut off valve. It is mounted at the end of the galley by the sink and next to the side door so it can be used to supply water to the sink or to an outside shower. The pump does have to be run to supply cold water for temp regulation when the water is hot. The tank is insulated so water is still warm in the morning after cooling over night.
I purchased a 12V 200W element to experiment with, but even with my 160 Ahr Lithium battery it is a bit too power hungry for comfort. With your larger battery you may find it works well:
https://www.banggood.com/12V-200W-1_...r_warehouse=C\
I installed a Chinese 240V 1000W or so element for heating the water when I'm parked for prolonged periods. Strictly a manual operation to heat via a genset for 10 to 20 minutes once/day. After two years I'm still pleased with it.
Bob M - 2002 and 2003 T1N ex-ambos in Qld. 2003 Freightliner/MB Cruiser in New England
bobmac is offline   Reply With Quote
The Following User Says Thank You to bobmac For This Useful Post:
cliff1654 (05-25-2019)
