Go Back   Sprinter-Forum > General Forums > Sprinter Talk > Scanners
Old 01-06-2019, 05:31 PM   #11
Winterbagoal
Default Re: Anyone managed to connect a scan gauge to 16+ sprinter?
Originally Posted by damien89 View Post
How do i force the communications protocol?
One more quick question. Is the key in the "RUN" position, or the engine running, when you get the never ending "Connecting" message?
FORCE/SELECT THE PROTOCOL:
You'd have to connect to a different vehicle with it, or it could be powered by the OBDII that it won't connect to. (I think? never tried it)
Then press "MORE" then "MORE" then "MODE".
Using the left and right arrow buttons, you can scroll through the available list of protocols that the SGII supports.
From the SGII manual troubleshooting section:
Never stops saying
“Connecting...”
Vehicle ECU not on Turn key to RUN or start engine <<<<
ECU not responding properly
Use MORE>MORE>MODE and try
Forcing the following modes:
FORD Products: PWM or CANSF
GM Products: VPW , ISO or CANSF
Chrysler Products: ISO, VPW or CANSF
Volvo Products: ISO, CANSF or CANLF
Others: ISO, KWPS, KWPF, CANSF,
CANLF, CANSS or CANLS
Where to Get Support
Online: www.ScanGauge.com/support
www.facebook.com/ScanGauge
Toll Free: 1-888-433-5664
E-mail: support@linear-logic.com
Mike.
2018 (2017 Sprinter Cab Chassis) N24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Winterbagoal is offline   Reply With Quote
Old 01-06-2019, 08:10 PM   #12
damien89
Originally Posted by Cheyenne View Post
But will this ScanGauge work on your Transit or the one off your Transit work on your Sprinter?
The one off my transit didn't work on my sprinter
2017 Sprinter 516cdi OM 651 7G-Tronic LWB 'LongTail'
damien89 is offline   Reply With Quote
Old 01-06-2019, 08:11 PM   #13
damien89
Originally Posted by Winterbagoal View Post
So, you have 2 X Scangauges? You say "the other scangauge" works on another vehicle. Your Transit.
I meant you should try the same SGII that won't connect to your Sprinter, on a different vehicle, preferably gas, but not critical.
Unless I'm misreading your comments.
Dammit Cheyenne, you asked my question.
I'll try that, thanks!
Old 01-06-2019, 08:12 PM   #14
damien89
Never stops saying
“Connecting...”
Yeah i tried all that even with the engine running, stays in the connecting screen then shuts down.
Old 01-06-2019, 09:19 PM   #15
Ok.... then what i'd do (on a day i was willing to trudge through "tedious, unrewarding") is plug it into the Transit ... where it will connect.
Then, still on the Transit, go into the menu system and tell it to use an MB-likely protocol.
(the LinearLogic instructions actually say that, but it's not obvious at 1st/2nd/3rd glance)(well, it took me 4)
(i don't have an NCV3 available, but i'll go out in a bit and see what my T1N is using (i think they changed the protocol during/after 2006)). *Done ... see next posting* (I'm KWPF)
Then take it back to the Sprinter and see if it's happier.
Rinse and repeat until you've gone through all the (dare i say 'likely', or shall i leave it at 'all'?) protocols
The other approach would be to call Linear Logic and ask them how to reach the protocol screen when it's stuck in "connecting..." screen. (but on 4th reading i see that they say: use another vehicle)
Old 01-06-2019, 11:18 PM   #16
OK.... my 2005 T1N uses the "KWPF" protocol.
Here's the scangauge manual for finding/forcing the protocol ("mode"):
... so it involves tapping the More button *twice* in rapid succession to get there,
then tapping the MODE button on the upper left.
(according to my manual, the Mode button is accessible when it's saying "Connecting...", but i couldn't test that)
...but you do need the key to be in the Run position.
If you do choose to manually select a Mode, run through the choices by tapping either button to the side of the displayed Mode.
When you reach one you want to try, press the FORCE button ... that locks it into the ScanGauge's memory.
That way it will be remembered as you trot the ScanGauge back from the Transit to the Sprinter.
good luck
Old 01-09-2019, 05:45 AM   #17
damien89
Attachment 105970
good luck
Thanks!! Will have a go again at it tonight.
Old 01-12-2019, 03:52 AM   #18
sailquik
sailquik's Avatar
Guys,
I was able to simply hook up a Scan Gauge II in the 2019 Demo Van I wrote about.
I did about 75 miles (40 without the SGII) and 35 with a Scan Gauge II that had last been
used (and set up for) an earlier Sprinter (2012 I think).
Not all the PIDs worked, but the important ones like % engine Load (LOD), Engine RPM, MPH,
MAP, etc. seemed to work just fine.
I didn't need to change any protocols or anything else.
I just plugged it in to the much easier to access OBD-II port and it worked.
Hope this helps,
Old 01-14-2019, 05:43 PM   #19
While working with another member's 2008, i was able to test my ScanGauge ...
(a) when it's showing "Connecting...", the "MORE" button *is* active, and can be walked to the MODE setup screen.
(b) the 2008 uses the CANSF setting for MODE (automatically detected in this 2008 case)
--dick (whose T1N uses KWPF)
Old 02-12-2019, 12:52 PM   #20
CalicoJack
damien89
Have you had any luck with this?
I have the same issue with my 2016 316 4x4 sprinter.
I have tried switching the SG to different protocols with no success. The same SG works perfectly on my other car
Cheers,
Jim
CalicoJack is offline   Reply With Quote
