Go Back   Sprinter-Forum > Sprinter-Based RV's & Conversions > Sprinter-Based RV Brands > Leisure Travel Vans > Free Spirit
Old 08-11-2018, 11:07 PM   #1
jms
Default Second Coach Battery Installation
Hello,
Can anyone advise me regarding installing a second coach battery?
The current battery (100 AH AGM) is located in a tray under the rear sofa driver side.
I understand a second battery can be installed under the passenger seat. Mine is the swivel type. Are installation instructions available online? A forum search did not find any. I'm curious about where the new cables will be routed and connected. What fuses are needed? Must a battery tray be installed under the seat?
Thank you,
Jerry S
2003 Leisure Travel Free Spirit SHC LWB
S FL
jms is offline   Reply With Quote
Old 11-11-2018, 06:12 PM   #2
Windrat
Default Re: Second Coach Battery Installation
I have three coach batteries the one you describe ( by the way pop that cover and do a clean up on that battery on a regular schedule) but I also have one under the hood drivers side and an other in a battery case behind the driver seat. the space under the passenger seat is reserved for tools. I run 190watts of solar and everything seems to be happy. I also have a 3000 watt inverter that is also mounted behind the drivers seat but dont run ac or microwave off it as it is a cheap square wave unit. Mainly use it for a juice blender. one of these days when I feel rich I may upgrade to a sign wave unit
I use marine deepcycle dual purpose batteries so in a pinch I can use the coach batteries to boost the starter.
Windrat is offline   Reply With Quote
Old 11-22-2018, 10:48 PM   #3
BaywoodBill
pre-Yuppiedom
BaywoodBill's Avatar
Search this Free Spirit forum for swivel seat removal. Quite a long thread.
Baywood Bill
2005 2500 cargo, long, tall
