Old 06-14-2018, 03:08 PM   #1
Munmile
Default Sliding Door step trim install
Hi All,
I've added some photos showing the addition of passenger van step trim to my cargo van.
I think it cleans the step up nicely and was only $46. Took 5 minutes to install. Attachment via 3 screws at the ends and 6" of VHB tape to secure the middle.
MB PN: 906-686-10-10-7J69
cheers
Munmile
https://sprinter-source.com/forum/at...1&d=1528988715
Munmile is offline   Reply With Quote
The Following 5 Users Say Thank You to Munmile For This Useful Post:
Mickyfin (05-09-2019), Obliged (06-14-2018), PRM95959 (03-01-2019), Ski Trip (07-25-2018), sprint2freedom (06-15-2018)
Old 06-15-2018, 03:30 PM   #2
Farfrumwork
Default Re: Sliding Door step trim install
You are full of good ideas Munmile. Thanks!
My floor is a bit elevated due to the MLV I installed underneath, maybe 0.25". Could the step trim just ride a bit higher to account for the floor height? I cant see the interface of the trim to floor with the carpet you have in there.
I was going to make a trim piece to fit, with some aluminum angle as a top trim, but this would be easier for sure. (but not as cool as my idea that included some color to match the other accents we have planned)
Farfrumwork is offline   Reply With Quote
Old 06-15-2018, 04:39 PM   #3
Munmile
Check out this pic, it shows two mounting holes to secure the trim to the B pillar. the top one lines up nicely with the height of stock plywood floor. The bottom hole is about 0.25" lower than the top
so it makes sense that you could use the lower hole and have a perfect fit. The two other attachment points are in the vertical plane and can accept any height you have a screw for.
cheers
Munmile
The Following User Says Thank You to Munmile For This Useful Post:
Old 06-18-2018, 05:27 PM   #4
Farfrumwork
thanks.
I would need a trim piece made for the step lighting, which my cargo van has. The trim piece you have has a embossed section where the light mounts on mine (there is a trim piece just at the front most short wall that is part of the lighting option).
thanks again!
Old 06-18-2018, 05:35 PM   #5
Munmile
thanks.
thanks again!
Yes there is a different specific part number for trim with provision for light. The part number I posted is blanked where the light goes.
Cheers
Munmile
Old 07-24-2018, 09:26 PM   #6
Farfrumwork
I ordered the version with provision for the light.
906-686-17-10-7J69
$32.xx (plus shipping, so ~$50)
I'll post a photo once I have it installed.
The Following User Says Thank You to Farfrumwork For This Useful Post:
Old 07-25-2018, 08:18 PM   #7
Ski Trip
Originally Posted by Munmile View Post
Hi All,
cheers
Munmile
thanks for posting, where did u order this from?
2017 144" WB Low Roof 4x4 ("Van Haley")
Ski Trip is offline   Reply With Quote
Old 07-25-2018, 11:20 PM   #8
Munmile
Any Mercedes dealer or online parts supplier can get them.
I got this one from walter's mercedes, Riverside, Ca.
Cheers
Munmile
Old 07-25-2018, 11:48 PM   #9
Ski Trip
Cheers
Munmile
thanks that is what I inferred from your original post, however I was in disbelief it could only be $46 from the dealer. they must really be finished building the NCV3ís!
Old 07-28-2018, 02:23 PM   #10
Ski Trip
little confusion on my end (nothing new)...
I am told your part number does not fit my van, and I need 906-686-07-10-9E80, which is $109. This is from an MB parts dept that has yours in stock but would have to order the one specifically for my VIN number. eh?
