Old 05-11-2019, 03:44 PM   #191
wankel7
Default Re: Thule- new awning option
Originally Posted by az7000' View Post
Attachment 112127
My question looking at this picture is about rain, are these awnings only for sun? Sure seems like the water would run down the side right into the door or window openings, the second pic in the above post too.
Any users who can speak to this?
Put this stuff above windows or doors.
https://www.amazon.com/Trim-Lok-DRB-.../dp/B06VWRJZ3W
wankel7 is online now   Reply With Quote
Old 05-21-2019, 06:35 AM   #192
DirtDogg
We have produced a limited run of awning mounts. We did a test fit-up with an 8ft awning on a 170 which would not be a good choice because the sliding door when open will interfere where you would need to place the brackets for the support legs. The legs were actually about 6" short to reach the ground but they did work. Not sure if the legs on the 10ft are longer. We have VHB backed threaded pads for vehicle mounted leg brackets as well. Similar to what we offer for the Fiamma. We ordered the brackets direct from Thule. Here are some photos. Please contact Kim via DIYvan to get pricing and order. Recommend 3 mounts for 10 ft awning. Would not mount an 8ft awning on a Sprinter. Some photos:
prototype bracket installed. There are EDPM pads where bracket contacts the vehicle body.
I'm not seeing these on your ebay store. Are you planing to produce more? Any way you can angle then the brackets up more. Even with the grommets, its still pretty awkward to close the awning. It would also prevent scratches/paint damage to the van.
DirtDogg is offline   Reply With Quote
Old 05-23-2019, 04:51 PM   #193
THE
It appears that the Thule Replacement Square Head Bolt 853-208909 is out of stock on Amazon. Looking at eTrailer it appears that they may have something similar/same.
I'm wondering where else to source this as I am mounting my Rack Mount to my custom roof rack where I'll be welding on plates to the rack and then mounting to the plates.
Amazon lists the general dimensions of the T bolt, I'm wondering how tough it would be to make my own?
Any advice/thoughts greatly appreciated.
TH
THE is offline   Reply With Quote
Old 05-24-2019, 12:22 PM   #194
Montucky
Attachment 112127
I was working on my van the other day in a light/moderate rain, and the partially extended awning did a good job of keeping rain away from the door, and nothing was leaking between the awning and the roof. I think this is because the factory roof rail is recessed into the Sprinter roof which creates a lip that keeps water on the roof side. I don't know how well it would work in a downpour, but in moderate rain it worked great.
Montucky is offline   Reply With Quote
Old 05-24-2019, 03:30 PM   #195
THE
Found elevator bolts at ACE and Lowes, the 5/16-18 and 3/8-16 both look beefy enough but will need to be modified to fit into the T-slot on the awning (cut flat head to slide into slot). I've looked at the ASME specs and these bolts are pretty tough.
I bought one home to trial fit and check it out. I'll post the results. They're less expensive, strong, and readily available.
Also, looks like if you do a search on Amazon for Thule Roof Rack Fairing Replacement Square Head Bolt M6 x 26-853208909 they are available and in stock at $4.95 each plus shipping. So for 12 that's about $64 shipped, for some dang bolts!
TH
Old 05-27-2019, 05:42 AM   #196
hein
Van Guru
We have had enough requests that we will have more made.
All the best,
Hein
DIYvan
2010 MB 3500 RV conversion.
Old 05-29-2019, 01:51 PM   #197
slopeboulder
All the best,
Hein
DIYvan
How soon do you think these brackets will be available? Will 3 mounts work on a low top?
slopeboulder is offline   Reply With Quote
Old 05-30-2019, 02:22 PM   #198
hein
Van Guru
The distance between the ridge at the top of the wall and roof rail is more on a low roof and our current bracket design does not fit. I will take a look to see if we can updated the design for your application.
All the best,
Hein
Old 05-31-2019, 02:02 AM   #199
slopeboulder
All the best,
Hein
Thanks, I was afraid of that third mount in the middle might not work. I have a 10' ready to install.
Old 06-15-2019, 08:49 PM   #200
zipperje
Hate to admit it but I am now thoroughly confused about which mounting brackets are best for the 10' Thule Hideaway, mounted on OEM roof rails. I bought my awning last summer and used 2 of the stock Thule brackets (just an L bracket) available at the time. Now I want to upgrade my brackets to a threesome to resist some of that torque and hopefully bring the awning out a little from the rail to provide better clearance for the crank.
Has anybody used this? It seems to be a redesign from the predrilled and powder coated L-brackets I used last summer. http://www.thule.com/en-us/us/van-ac...mount-_-301668
zipperje is offline   Reply With Quote
