Old 04-19-2018, 05:16 AM   #21
Brad75
Default Re: Bed suggestions with moto & mtb in mind
you could do one on each side with a support in the middle between the bikes for adding strength. looks like just e-track with some type type of hinge point.
https://s5.postimg.cc/ab4ilclp3/Capture.png
Brad75 is offline   Reply With Quote
Old 04-19-2018, 05:19 AM   #22
Brad75
im in the same boat, just smaller lol ... my mini bikes are only 34'' off the ground with the handle bars down.
https://s5.postimg.cc/pjufz4ut3/IMG_1053.jpg
https://s5.postimg.cc/oubnms1zb/IMG_1067.jpg
Old 04-19-2018, 11:49 AM   #23
turn_one
If only I were in the same boat, life would be so simple.
turn_one is offline   Reply With Quote
Old 05-06-2018, 02:29 AM   #24
DonPatrol
If you are up for a project, this bed looks like the ultimate
https://creatid.com/news/sprinter-co...le-bed-system/
I just ordered a Moab bed, they guys at Adventure Van a great, It's supposed to arrive in a few days.
DonPatrol is offline   Reply With Quote
The Following User Says Thank You to DonPatrol For This Useful Post:
turn_one (05-08-2018)
Old 05-07-2018, 03:59 AM   #25
julie777
Julie
I'll add my 2 cents.
Happi jack is too heavy for me. Moab is too expensive.
I am using harbor freight ramps for the frame because they are cheap and light. However, I wanted to be able to adjust the height and also to maximize the width to sleep crosswise. I finally decided that the best answer was the moab bed mounting kit because I don't currently have the ability to fabricate the bracers for the window openings and I wanted the vertical L track to be inset and flush with my horizontal L track. So, that was $900 added to my $75 for the ramp. I am going to make my own angles to bolt horizontally to the to the L track. I am also going to modify the ramp sections to adjust in width. (They won't be a quick adjust like the moab, but I don't really expect to move it around much after I find the right height.)
The Following 2 Users Say Thank You to julie777 For This Useful Post:
mtbkers (05-08-2018), turn_one (05-08-2018)
Old 05-08-2018, 01:48 PM   #26
turn_one
I was looking at this guys work the other day. Heís a talent for sure. Donít think that bed is for sale though.
Old 05-08-2018, 01:52 PM   #27
turn_one
Seems to me if youíre making the horizontal pieces then all you need is the vertical l-track and bed/frame. Iíve seen people take stock (non contoured) l-track and secure then to the vans framing conforming them with clamps (and a few extra set of hands). You may be able to save the $900 if you havenít already purchased and wanted to try this.
What will you be using for the bed surface and frame?
Old 05-08-2018, 04:14 PM   #28
dodger413
Location: joshua tree, ca or western massachusetts 2008 170" high cargo
what powers the up / down movement of the "CreatID" bed ??
two humans ? one at each end of the bed ??
and would that bed be able to have a higher travel ? closer to the ceiling ?
it might be fine for bicycles after removing the wheels, but there is no such arrangement for fitting a full size motorcycle under that bed.
dodger413 is offline   Reply With Quote
Old 05-23-2019, 06:11 AM   #29
cdshrack
I had looked at the "CreatID" bed last year, and now they have launched modularvan.com where they are selling a pretty interesting product.
cdshrack is offline   Reply With Quote
Old 05-24-2019, 11:09 AM   #30
feynmanfan
Lippert Components makes the HappiJac but they also offer the Euroloft which is the system I chose. Lighter and simpler and has worked great for us. Winnebago chose it for their Revel.
feynmanfan is offline   Reply With Quote
