Old 07-05-2018, 05:02 AM   #11
Vulgar Ninja
Default Re: NCV3 sliding door track removal
Thank you Munmile and mike01001. I will update with any progress... HAPPY 4TH!!!
Vulgar Ninja is offline   Reply With Quote
Old 11-08-2018, 01:54 AM   #12
Munmile
Hi All,
In the process of fitting a black painted rail to my 2018 144" Cargo I discovered two neat things: First, it seems you can order a black rail from the factory parts bin because that's what I got with PN: A 906 766 07 37. Second, using a 1" wide, 20' ratchet strap with hooks on each end and an eye bolt I was able to switch out the rails in under 30 minutes by myself. As can be seen in the pics, the object of the strap was to unweight the sliding door allowing the rail to be R&R'ed.
After removing the M6 flanged nuts from the inside and removing the T30 torx screw from the forward end of the rail, the unweighted door/rail can be propped out by several inches with a roll of cloth between the door and the body to allow room for removal and reinstallation. The plastic
piece at the back end of the rail must be removed to allow the door roller to exit the rail. I used an eye bolt with a long thread and adjusted the nuts to provide a fine adjust of the ratchet positioning such that the door was floating nicely in the rail before attempting to space out the door and withdraw the rail. Also added the trim piece for a finished look at the back of the rail groove.
cheers
Munmile
https://sprinter-source.com/forum/at...1&d=1541644448
Munmile is offline   Reply With Quote
The Following 6 Users Say Thank You to Munmile For This Useful Post:
luckworthy (11-17-2018), manwithgun (05-08-2019), Mickyfin (05-08-2019), Obliged (11-08-2018), sprint2freedom (11-09-2018), TheHerd (11-08-2018)
Old 11-08-2018, 02:12 AM   #13
ptheland
2013 144" low top Passgr
ptheland's Avatar
So you put the strap over the top of the car and tied it down to the wheel on the opposite side of the van? I'm not sure I'm understanding that part from the pictures - there's no real overall pic of the setup.
--Peter
Old 11-08-2018, 02:20 AM   #14
Munmile
Yes strap over the top, down to the wheel for attachment.
Sorry no pics of the strap going all the way over but you've got the drift.
Cheers
Munmile
The Following User Says Thank You to Munmile For This Useful Post:
ptheland (11-08-2018)
Old 11-08-2018, 03:24 AM   #15
ptheland
ptheland's Avatar
Thanks for the clarification. It's very clever in that you don't need to worry about balancing the door on some kind of jack at the bottom. Just have to keep it from swinging around. I might be able to put the idea to use on a stubborn minivan sliding door.
--Peter
Old 03-21-2019, 04:54 PM   #16
bikebum
Hi All,
Did you spray paint the rail?
If so How has it held up?
I was considering powder coating but the turnaround is about a week. Canít leave to door open for a week...
bikebum is offline   Reply With Quote
Old 03-21-2019, 05:00 PM   #17
Munmile
I bought a black powder coated rail from Mercedes, A 906 766 07 37.
Swapped rails very quickly using the method shown earlier in the thread.
cheers
Munmile
Old 05-08-2019, 12:16 PM   #18
Mickyfin
Mickyfin's Avatar
Hi All,
cheers
Munmile
Superb, I think I will go this route once I have sourced a 170" wheel back rail from the stealers, unless it works out cheaper to powder coat myself.
Anyone know the part number of the black rail for the LWB 170" Sprinter, our are they the same?
Old 05-08-2019, 06:16 PM   #19
Munmile
They are the same
Munmile
Mickyfin (05-09-2019)
Old 05-09-2019, 04:02 AM   #20
Mickyfin
Mickyfin's Avatar
Excellent, managed to find a used part for €45 shipped, bargain! In black too.
