SubForums: Events Scanners
Old 05-25-2019, 09:02 PM   #3771
Bob Laps
Bob Laps's Avatar
Default Re: What did you do to your Sprinter today.
Originally Posted by Mickyfin View Post
Fit my fresh powder coated OEM allows, and KO2's, very slight rubbing on right full lock, and thats with 245/75/R16. I do plan on a 5" lift kit later this year though, so that will be rectified.
Untitled by S STEEL, on Flickr
5"??......that's gonna be huge"
Bob
Bob
2017 3500 ext
Bob Laps is offline   Reply With Quote
The Following User Says Thank You to Bob Laps For This Useful Post:
sebtown (05-27-2019)
Old 05-25-2019, 09:57 PM   #3772
Some Euro sprinters are sold with a 1-2" lower ride height than the factory 2WD units in North America. So its not as tall as it might sound. The 4x4s are lifted something like 4" from the NA spec 2WD, so 5" probably would put the sprinter in line with NA 4x4s.
Mickyfin (05-26-2019)
Old 05-26-2019, 04:20 AM   #3773
Mickyfin
Mickyfin's Avatar
Bob
Correct, thats what kit the place has at the moment, but if they have a 3" lift kit available by the time I head to the UK, I would opt for that instead.
Mickyfin is online now   Reply With Quote
Old 05-26-2019, 07:29 PM   #3774
BrennWagon
Pete
I hit my steering wheel with a couple of coats of Krylon. I have a leather cover coming so I didnít worry about the rim too much
File Type: jpg CA82C6AA-77AC-4436-A114-415AF4CB7869.jpg (98.5 KB, 131 views)
BrennWagon is online now   Reply With Quote
The Following 2 Users Say Thank You to BrennWagon For This Useful Post:
Aggie (05-26-2019), Mickyfin (05-27-2019)
Old 05-27-2019, 08:54 PM   #3775
BrennWagon
Pete
Finally installed my auxiliary battery and isolator under the seats. They really made it painless when they designed these vans
Old 05-28-2019, 01:05 AM   #3776
Koolaid
Completed the right of passage.
2018 144 high top Crew
Koolaid is offline   Reply With Quote
The Following 2 Users Say Thank You to Koolaid For This Useful Post:
Mickyfin (05-28-2019), sassmatt72 (05-28-2019)
Old 05-28-2019, 01:17 AM   #3777
Nubes
Hi Brennwagon, would love to hear about your auxiliary battery install since we have the same year T1N. Any pics? Thank you 😊
Nubes is offline   Reply With Quote
Old 05-28-2019, 04:12 AM   #3778
BrennWagon
Pete
I just followed the instructions that I found in this forum. Running the wires through the firewall was simple once you cut the zip tie holding the grommet together. I found that feeding it through from the interior on the top of the loom (but inside the grommet) was easy, the factory put all the channels you need in and easily accessible. I made my own battery tray, beyond that it was pretty standard. Now I just need to connect the accessories to my house battery. Stereo and amp are definitely going on there, as well as the dome lights and eventually some 12V and USB outlets where the ashtrays are in the back (140 PW) I setup a relay array for lights, towing wiring, etc. that Iíll switch over to it too. Iím thinking about putting a switch on the isolator relay to allow me to connect the batteries if I need some extra juice to start
I only took pictures of the battery tray in place, I got into the groove and buttoned everything up before I remembered to take pictures
File Type: jpg A6E9BE53-02B2-4ED3-9FAD-702C87E15CB0.jpg (73.0 KB, 98 views)
Nubes (05-30-2019)
Old 05-28-2019, 04:29 AM   #3779
GSWatson
2013 144
GSWatson's Avatar
You might want to think about adding a wooden reinforcement to the inside; that sheet metal is pretty thin, and any flexing will stress your sealant. The inside ring, ideally of plywood, will give the top screws something to grip into, and will also make the interior trim much more stable, as it will screw into the wood as well. Make it the same thickness as the interior ribs.
I have a better picture somewhere, but this is all I can find on the spur of the momentÖ
Cheers,
Greg
Koolaid (05-28-2019)
Old 05-28-2019, 11:46 AM   #3780
Koolaid
Greg,
I know. I had a frame for inside made out of 2x2’s but it wasn’t seating properly and would block the stock light from going back properly. I then tried using a scrap price of plywood from bed but it wasn’t the right size. I then tried using strips on 3 sides which would be better than nothing, and give the light enough room. But I ran out of time. I hated not using anything and am a little freaked out about leaks. I’ll be back up in ceiling before too long to insulate and run wires for lights and will reassess the situation. There’s not much I can do now that the lap sealant is on tho. Hoping for the best!!! But worried about the worst.
