Go Back   Sprinter-Forum > Regional Discussions > Europe
Old 03-06-2017, 11:23 AM   #1
fisjon
fisjon's Avatar
Default Electrical Gremlins, check this out!
A potential source of electrical problems can arise from the wiring loom Under the cab of T1N Sprinters.
The wiring loom that goes under the cab from the engine compartment before it goes up into the cab and connects to the relay/fuse box under the drivers seat has a braided earth wire attached to the under side of the cab under the passenger seat area.
This earth wire chaffs on the wiring loom and can cut through any one of a number of cables causing untold frustration.
If you have gremlins, check it out.
fisjon is offline   Reply With Quote
The Following 2 Users Say Thank You to fisjon For This Useful Post:
autostaretx (03-06-2017), SneakyAnarchistVanCamper (03-19-2017)
Old 08-07-2018, 10:24 AM   #2
MarBob
Default Re: Electrical Gremlins, check this out!
Will CK this out. Thank You!
MarBob is offline   Reply With Quote
Old 08-07-2018, 06:22 PM   #3
autostaretx's Avatar
For US/Canada people reading this thread: note that the original post was from the UK (right-hand drive), so his routing differs from "ours".
(but it's still worth checking)
Most of our T1N wiring from the engine compartment passes through the firewall, near the battery's negative post.
