I just had a New York State inspection done today and the printout at the end showed 3 active recalls, but did not identify them.
From past experience I know that is the faulty metal tire valves, which have all been replaced for years, and the manifold recall, which I never had done.
No idea what the 3rd could be.
NHTSA.gov website only lists the tire valve recall for my VIN #but does list the following for 2002 Freightliner 2500s
4 Recalls
for 2002 FREIGHTLINER SPRINTER 2500
FILTER RECALLS BY AFFECTED COMPONENTS
All (4)ENGINE AND ENGINE COOLING (2)INTERIOR LIGHTING (1)STEERING (1)
August 9, 2011 NHTSA CAMPAIGN NUMBER: 11V410000
INTAKE MANIFOLD
INTAKE MANIFOLD CORROSION MAY LEAD TO AN EXHAUST GAS LEAK, DAMAGE TO THE FUEL RETURN LINE WHICH COULD CAUSE A FUEL LEAK, AND HEAT DAMAGE TO THE INSULATION AT THE FIRE WALL. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
NHTSA Campaign Number: 11V410000
Manufacturer SPRINTER ENGINEERING & COMPLIANCE SUPPOR
Components ENGINE AND ENGINE COOLING
Potential Number of Units Affected 665
Summary
MERCEDES-BENZ USA (MBUSA) IS RECALLING CERTAIN MODEL YEAR 2002- 2003 SPRINTER 2500 AND 3500 VANS SOLD AS DODGE AND FREIGHTLINER VEHICLES. THE INTAKE MANIFOLDS MAY HAVE CORRODED. A CHEMICAL REACTION INVOLVING SULFUR IN THE DIESEL FUEL THAT TAKES PLACE UNDER CERTAIN CONDITIONS CAN LEAD TO THE FORMATION OF SULFURIC ACID IN THE EXHAUST CHANNEL OF THE INTAKE MANIFOLD.
Remedy
DEALERS WILL INSPECT AND REPLACE THE INTAKE MANIFOLD FREE OF CHARGE. CHRYSLER, LLC WILL NOTIFY OWNERS OF DODGE SPRINTERS AND MBUSA WILL NOTIFY OWNERS FREIGHTLINER SPRINTERS. THIS RECALL IS AN EXPANSION OF A PREVIOUS RECALL (PLEASE SEE RECALL CAMPAIGN 09V-418). THE SAFETY RECALL BEGAN ON OCTOBER 11, 2011. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403 OR SPRINTER AT 1-843-695-5031.
Notes
MBUSA'S SAFETY RECALL NUMBER IS 2010040002. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV .
8 Affected Products
9 Associated Documents
Request Research (Services fees apply)
October 29, 2009 NHTSA CAMPAIGN NUMBER: 09V418000
EXHAUST CHANNEL
INTAKE MANIFOLD CORROSION MAY LEAD TO AN EXHAUST GAS LEAK, DAMAGE TO THE FUEL RETURN LINE WHICH COULD CAUSE A FUEL LEAK, AND HEAT DAMAGE TO THE INSULATION AT THE FRONT WALL.
NHTSA Campaign Number: 09V418000
Potential Number of Units Affected 14,423
Summary
SPRINTER IS RECALLING CERTAIN MODEL YEAR 2002 THROUGH 2003 VANS SOLD AS DODGE AND FREIGHTLINER VEHICLES. THE INTAKE MANIFOLDS MAY HAVE CORRODED. A CHEMICAL REACTION INVOLVING SULFUR IN THE DIESEL FUEL THAT TAKES PLACE UNDER CERTAIN CONDITIONS CAN LEAD TO THE FORMATION OF SULFURIC ACID IN THE EXHAUST CHANNEL OF THE INTAKE MANIFOLD.
Remedy
DEALERS WILL INSPECT AND REPLACE THE INTAKE MANIFOLD FREE OF CHARGE. CHRYSLER, LLC IS HANDLING THE OWNER NOTIFICATION AND REMEDY FOR THIS CAMPAIGN. THE RECALL BEGAN ON JUNE 4, 2010. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403 OR SPRINTER AT 843-695-5031.
Notes
SPRINTER SAFETY RECALL NO. 2010040002. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
8 Affected Products
18 Associated Documents
July 24, 2008 NHTSA CAMPAIGN NUMBER: 08V339000
STEERING COLUMNS
THE OPERATOR MAY LOSE STEERING ABILITY OF THE VEHICLE INCREASING THE RISK OF A CRASH.
NHTSA Campaign Number: 08V339000
Components STEERING
Potential Number of Units Affected 10
Summary
SPRINTER IS RECALLING 10 MY 2001-2006 DODGE AND FREIGHTLINER 2500 AND 3500 VEHICLES. THE WELDING SEAM BETWEEN THE BRACKET AND STEERING COLUMN OF AFFECTED SPARE PARTS DOES NOT MEET DESIGN SPECIFICATIONS. THE RESULT OF AN OUT OF SPECIFICATION WELDING SEAM IS THAT THE STEERING COLUMN MAY DETACH FROM ITS INTERIOR VEHICLE MOUNTING BRACKET.
Remedy
DEALERS WILL INSPECT AND REPLACE THE STEERING COLUMNS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE FEBRUARY 16, 2009. OWNERS MAY CONTACT SPRINTER AT 843-695-5057.
Notes
CHRYSLER'S RECALL NO. H25. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV.
24 Affected Products
11 Associated Documents
July 13, 2007 NHTSA CAMPAIGN NUMBER: 07V299000
REAR AIRCONDITIONING/INTERIOR LAMPS
THE SWITCHING CONTACTS OF THE LAMP MAY CAUSE A SHORT CIRCUIT OF THE REAR LAMP INCREASING THE RISK OF A FIRE.
NHTSA Campaign Number: 07V299000
Manufacturer DAIMLERCHRYSLER MANUFACTURING INTL
Components INTERIOR LIGHTING
Potential Number of Units Affected 4,433
Summary
ON CERTAIN TRUCKS EQUIPPED WITH REAR AIR CONDITIONING SYSTEM, THE INTERIOR LAMP IS EQUIPPED WITH AN 18W LAMP AND A SCATTERING LENS. IN EXTREMELY HOT AND HUMID CONDITIONS, THE COMBINATION OF HEAT AND HUMIDITY, AND THE HEAT FROM THE LAMP DUE TO EXTREME LONG TERM OPERATION, CAN DISTORT THE SCATTERING LENS.
Remedy
DEALERS WILL REPLACE THE REAR INTERIOR LAMPS FREE OF CHARGE WITH A MODIFIED VERSION WHICH IS NOT SUBJECT TO THE IMPACTS OF HEAT AND HUMIDITY. THE RECALL BEGAN ON DECEMBER 17, 2007. OWNERS MAY CONTACT DAIMLERCHRYSLER MANUFACTURING INTERNATIONAL AT 1-843-695-5041.
Notes
12 Affected Products
15 Associated Documents
