Go Back   Sprinter-Forum > Regional Discussions > USA
Old 08-30-2019, 10:46 PM   #1
Mike Rancourt
Default San Diego, sharing tools for free
Hi. Iíve had to do a few projects lately he required me to buy some specialty tools, and I thought Iíd like to offer these and other somewhat specialty tools to share locally for free. If youíre in the San Diego area and youíd like to borrow something, send me an email at mikerancourt [AT] hotmail.com. Iíve done the jobs listed, but Iím not so great at mechanics (note TWO broken injector bolts!), so donít rely on me for expertise. Also, this offer is to share tools for free. Donít offer me cash or alternative currencies like beer (I donít drink, but thats beside the point).
Here are some things I have:
- injector hard fuel line wrench (14mm, 17mm, 19mm). Used for injector or fuel rail work.
- injector puller. Used for, well, pulling a stuck injector.
- in-lbs torque wrench (I have. 3/8 drive and a 1/4Ē drive, but I honestly donít know if h 1/4Ē drive is defective or if I just donít know how to use it because I used it twice as broke two effing injector hold drown bolts!). Used especially for replacing injector hold down bolts, but could be used for other things of course.
- injector hold down bolt diy thread clean out tool made from the old bolt by cutting flutes in the sides and bottom (or you could borrow the rotary tool and make one for yourself since my flutes arenít pretty, though it seems to work well). Used for injectors work.
- 5/8Ē dowel with 400 grit sandpaper taped to the end. Used for resurfacing injector faces. It actually seems to work!
- wire bore brushes and regular wire brushes. Used as part of he proves of cleaning out his down bolts and injector hole.
- t40 bit; t30, t40, t45, t47 sockets (used for injector work, seatbelts, etc...)
- e4-e18 socket set. Used for work on the intake and probably other things.
- Time Sert ďbig sertĒ thread repair kit. Used for broken injector hold own bolt. I actually have two inserts left. You can have them. See my saga here.
- angle drill. Used for drilling out broken injector hold down bolt.
- 11/32Ē cobalt drill bit. Used for enlarging hold down claw hole.
- Irwin spiral flute extraction set. Used for backing out a broken injector hold down bolt (didnít work for me, but that my be because I didnít use a real center punch and do couldnít get a good grip).
- 18mm 3/8Ē drive socket (maybe you have one, but I donít when I needed to do this job and donít know it wasnít 19mm. Used for removing rear calipers.
- iCarSoft MBII scan tool (see this thread, though, to be honest, I think itís very hard to use even with a nice guide) used for scanning and learning codes in lots of systems.
To each according to need. From each according to ability.
- 2002 Freightliner 2500 Sprinter (800 miles on WVO)
- 1998 VW Jetta TDI (20k miles on WVO?)
- 1978 Mercedes 240D (2k miles on WVO)
Mike Rancourt is offline   Reply With Quote
The Following 5 Users Say Thank You to Mike Rancourt For This Useful Post:
BrennWagon (09-02-2019), DSchmidt7of7 (09-09-2019), Onefin (08-31-2019), SeattleMatt (01-03-2020), turbodave (09-12-2019)
Old 08-31-2019, 03:29 AM   #2
Onefin
Default Re: San Diego, sharing tools for free
That’s cool of you to make this offer!
Old 11-19-2019, 07:13 PM   #3
Coast2Coast
2006 158 Cargo
Coast2Coast's Avatar
Hi Mike. Very generous post. By chance do you know of a rv Sprinter electrical installer for inverters and batteries in San Diego you can recommend?
Coast2Coast is offline   Reply With Quote
