SubForums: Events Scanners
Old 11-28-2014, 01:44 AM   #1
1109
Default German Sprinter manual
Does anyone here know what the recommended oil change is in a German manual.
1109 is offline   Reply With Quote
Old 11-28-2014, 02:07 AM   #2
312d
Default Re: German Sprinter manual
gearbox or engine, or differential or ??
Eduardo Velásquez. 313CDI OM611 DE-LA; 312D OM014 LA
312d is offline   Reply With Quote
Old 11-29-2014, 01:36 AM   #3
1109
sorry the motor oil. Thanks
Old 12-08-2014, 05:25 AM   #4
312d
you can change your motor oil and oil filter without problems every 10 thousand miles, if you do speedways most of the time you can add another couple thousands without any troubles, if you use fully synthetic oils you can add a couple thousands more, without to have to think in anything, in fact there are studies wich says synthetics can withstand more than 50 thousands ( or so but it was an amazing amount that I cannot remind), but you need a special filtration system, so the weak point is the filter.
