Old 01-16-2019, 08:22 PM   #1
baggio95
Default Fuse Block/Breaker Box
I recently picked up a 2004 Vista Cruiser and was wondering if anyone's Blue Sea fuse block in the cabinet below the bed or breaker panel under the fridge is labeled? Thanks
baggio95 is offline   Reply With Quote
Old 01-28-2019, 07:44 PM   #2
Smbrick
Default Re: Fuse Block/Breaker Box
Here is my fuse box under the bed. The pencil scribbles are mine.
2006 Frieghtliner 2500 158" Hi-top - Gulf Stream Vista Cruiser MB
Smbrick is offline   Reply With Quote
The Following 3 Users Say Thank You to Smbrick For This Useful Post:
autostaretx (01-29-2019), baggio95 (01-28-2019), bcolins (02-27-2019)
Old 01-28-2019, 09:03 PM   #3
baggio95
Awesome, thanks Smbrick!! Appreciate the help. It at least gives me a starting point to track things back and figure mine out.
Old 02-13-2019, 06:55 AM   #4
Saturn949
I would also highly recommend to check each wire crimp. I got two loosed crimp on mine I had to fix it. Also if your kitchen light flicker when your pump turns on. I use standard 12v automotive relay contacts to drive pump directly from 12v distribution panel and switch on fume hood only drive coil of this relay
Saturn949 is offline   Reply With Quote
The Following User Says Thank You to Saturn949 For This Useful Post:
baggio95 (02-19-2019)
Old 02-19-2019, 12:06 AM   #5
baggio95
Appreciate the info Saturn. When the weather warms up I'll definitely be checking things out
