nouP
it is not
The Dearest Richard Called it Sprinter Deiman
MB called it decorated head rest
Nope! That's Boss Pig from the Dukes and hazards
Wombats are nocturnal! Being mischievous by nature ,they burrow from underneath... Favorite place of rest. is when WOMBAT digs his way through Middle Earth, to the US side of Topple Earth. Wombats not Happy untill they find an appropriate place of residence, such as a small metallic type hole, Sprinter centre bearing carries seem to fit the bill, then that's the sound of the bearing a Howling, when Wombats are working on the chain Ganggggggg, All day long
Wombat a Smiling..Gee he's so innocent
Second Generation of Aliens that jump, the turbo! and inhabit a new habitat, to squat in..NCV PSM box of tricks.. it's the coinciding resonance. of frequency ratios, that wont match up to a squaking Parrot.
Devils..one by one,they are migrating in force, to the USA
PS Turbo problems are only an illusion! it's when you run over our genetically modified Cane Toads Not those menacing Haywain
cane toads that's sound like a VW Kombi back fireing, when you drive over them... the rear end of an Australian Cane Toad has a built in resonator! nothing to do with MB ... under pressure it will fail
... It's Axel the Pop-Corn
Frog from UK side of the pond,playin' tricks there.
Not that it has single, 'thing to do with a swivel seat'...But you if you can swing a Cat! Then watch a Cane Frog... XPLODE "...After Dark''.
Richard
