Old 07-03-2019, 07:32 PM   #11
Patrick of M
2005 T1N 2500 (NA spec)
Default Re: Still looking for my perfect sprinter 1997 140" 412d manual
If it is not rusty it should pass inspection, and any fails would need to be addressed anyway so it is good policy. I used to run a 5cyl non turbo diesel van with a mechanical fuel pump, very reliable (tuning can be difficult but worth the challenge). Frankly for me the price is too high, but if it is in very good condition it may be right for you. I have traveled to buy vehicles before, it is impossible to negotiate when you have traveled far, if you want to knock down the price do it in advance, or make it very clear that you will be subtracting the cost of flaws etc.. a manual sprinter would be pretty tough and the fall off in performance due to the older engine tech might be balanced by the manual transmission and reliability of mechanical fuel injection.
Patrick of Montreal
2005 T1N (NA spec).
Old 07-04-2019, 02:30 AM   #12
badlash
I've double checked it is a manual transmission, So pretty excited about that. the guy who is selling is moving back to Germany and is offering to source and send parts back to canada which would be very helpful it that is the case. Probably would still take 3 weeks.
badlash is offline   Reply With Quote
The Following User Says Thank You to badlash For This Useful Post:
BrennWagon (07-04-2019)
Old 07-04-2019, 06:44 AM   #13
owner
owner's Avatar
For differences:
AFAIK apart from the engine and trans, the rest of the running gear brakes and suspension should be interchangeable with a CDI T1N. And by "Interchangeable" I mean you could bolt on whole parts on like front hubs and diff, not interchange stuff like brake pads.
The rear doors will have non-bonded windows, and the aforementioned headlights, bonnet and grille. Apart from that I think the body is identical.
The front seat pedestals are different, and front seats as well. No idea if they can be interchanged. And the dashboard and all electronics are different. Electronics are different in terms of there not really being any on the 312d.
So in summary it is a really good reliable option. As long as you keep a supply of the correct spares on hand it would be fine. Things like glowplugs, filters, injectors etc.
Did you guys get the om602 in any MB cars over there? that would be a great source of engine/trans parts.
Code:
Model indication	              Year	            Engine no OM602...	Power
OM 602.xxx (5-cylinder diesel)
W201 190 2.5 D & W124 250 D	04/1985 - 06/1993	.911 & .912 & .930 & .931	66 kW (90 PS; 89 hp) (<'89) or 69 kW (94 PS; 93 hp) (>'89)
G-Class 250 GD 4x4	.938 & .939
T1 210 & 310 & 410 2.9 D.	10/1988 -> 1995	.940 & .942	72 kW (98 PS; 97 hp) or 75 kW (102 PS; 101 hp)
G-Class 290 GD 4x4	.946 & .947
W201 190D 2.5 Turbo & W124 250D Turbo / 300D 2.5 Turbo	01/1987 -> 1996	A.961 & A.962	90 kW (122 PS; 121 hp) (<'88) or 92 kW (125 PS; 123 hp) (>'88)
Sprinter 2,5 Turbo-D.	A.963
212D & 312D & 412D & Sprinter 2.9 TD	02/1995 -> 04/2000	A.980 & A.986	90 kW (122 PS; 121 hp)
G-Class 290 GD turbodiesel 4x4	07/1997 -> 09/2000	A.983	88 kW (120 PS; 118 hp)
W210 E290 turbodiesel	03/1996 -> 07/1999	A.982	95 kW (129 PS; 127 hp)
https://en.wikipedia.org/wiki/Merced...z_OM602_engine
Old 09-14-2019, 02:42 PM   #14
SprinterLex
You guys seem to be the ones to ask my question.
My goal is to change my dually to a single wheel and get better mpg. A knowledge sprinter owner told me he thinks the best way to do this is to get 2500 donner van swap out
- rear differential
- ecu
- ignition and immobilizer
- Possibly the TCM
From what you guys are saying would it just be possible for me to switch the rear axel and the TCM box from a donner 2500?
OR if the ecu needs to be changed could I do this
- Swap out rear axel and TCM from Donner
- Use a green diesel tune with their additional Immobilizer delete package to remove any issues with the immobilizer and ignition switch.
- Swap Ecu from same 2500 donner that I got the ecu
OR even better
- Then maybe Green tune can just flash my ECU to match my new rear axle gear ratio and all is good. I probably get the immobilizer delete option anyways so if the ignition and immobilize won't be an issue regardless. I just want the ability to swap out my ignition switch for a used one if it starts going bad without paying the dealership my life savings.
Any thoughts? How would you guys switch the sprinter from a dually to a single axel? That's the main goal.
A secondary goal, that is not a must, is higher gear ratio for fuel economy since I never ever have a heavy load. So what do you guys recommend?
SprinterLex is offline   Reply With Quote
Old 09-14-2019, 03:15 PM   #15
Patrick of M
You should probably start a new thread, also contact GDE about tuning /programming changes.
Patrick of Montreal
2005 T1N (NA spec).
manual, t1n
