Go Back   Sprinter-Forum > General Forums > Sprinter Talk > Scanners
Old 05-11-2019, 03:05 PM   #1
cmderden79
Question Autel MD802 connection/fit issue
Just bought our first van, 2006 t1n 170 WB. At the recommendation of many on the forum our first purchase was the MD802 scanner.
Is it normal for the connection on these to be an extremely tight fit? Most videos I have watched it seems to pop right in, but both on my Fusion and the Sprinter I have to struggle to get it connected. The Fusion was finally able to make a good connection and get a scan...the Sprinter we could never even get it to power the unit.
Any help would be appreciated.
cmderden79 is offline   Reply With Quote
Old 05-11-2019, 03:29 PM   #2
Default Re: Autel MD802 connection/fit issue
The OBD plugs and sockets do have a fair (or unfair) amount of differences in terms of size tolerances and thus how well they fit.
Since we don't know (without extracting) who made the Sprinter's socket, and since we have no control over what make of plug the various scanners chose to put on the end of their cords (why does "low bid" spring to mind? ), it's pot luck as to how snug they'll be.
My ScanGauge plug takes a fair amount of force to fully seat and to start it coming back out again.
Since i'd like to have it stay snug when driving, i don't consider that a bad thing.
The plug on my DAD is a bit easier to get in and out, but could that be due to it missing one pin?
(i forget which signal the DAD ignores ... it's probably just the switched-by-ignition power feed).
When you're pulling and pushing, do try to remember to have it go *straight* in and out ... having the pins flex due to lateral twisting can cause them to break off in the socket.
cmderden79 (05-11-2019), DesertAdventures (08-13-2019)
Old 05-11-2019, 03:51 PM   #3
cmderden79
Thanks for the quick reply. Yeah I was definitely trying to keep it on the straight and true. Just surprised we couldn't get the sprinter to light it up at all. May buy a cheap Bluetooth just to see how it fairs at connecting.
Old 05-12-2019, 05:17 AM   #4
sprint2freedom
2008 NCV3 170ext
Perhaps try an OBD2 extension cable?
Old 05-12-2019, 04:16 PM   #5
bcislander
'07 Mercedes-badged Dodge
bcislander's Avatar
FWIW, I have had no problems connecting my Autel MD802 to the OBDII Port on my 2007 Sprinter and 2002 AudiA4, as well as friends' Mazdas and an Acura.
2007 Mercedes-badged Dodge 2500, GWV Legend RV
bcislander is online now   Reply With Quote
Old 07-08-2019, 08:51 AM   #6
ions82
I recently bought an Autel MD805 (newer/cheaper version of 802), and there was no way those connectors were going together. I bought an extension/splitter, and it went right on. I thought the connector on the van had been damaged, and I was poised to chop it off and wire on a new one. Glad the extension averted that hassle.
ions82 is offline   Reply With Quote
Old 07-25-2019, 01:04 PM   #7
Garandman
Garandman's Avatar
Running into same problem. The less expensive scanner I had fits right on. The Autel 802 I cannot get to connect, even pushing fairly hard.
Going to try switching the cables on the chance they are wired the same. At least I can compare them to see the difference.
When I push on the OBDII port, it gives way. Is it rigidly mounted? I'm thinking there's also something broken behind it.
2006 Sprinter 118 ~ 16 Rial Transporter rims ~ 235/65x16
Garandman is online now   Reply With Quote
Old 07-25-2019, 01:36 PM   #8
NewfD90
My 2006 has the same problem - this with the AP200 and the UltraGauge. Seems to be that the socket Merc used for 2006 was slightly different. That coupled with the fact that it's mounted on some flimsy plastic makes it hard to get a good connection. There's a hole on the left side of the socket mount plate that I stick my finger in so that I can stiffen up the mount plate while pushing really hard on whatever diagnostic tool I'm plugging in.
NewfD90 is offline   Reply With Quote
Old 07-25-2019, 03:23 PM   #9
I bought an extension cable for using with various scan tools. That may be an inexpensive option to dealing with the difficult plug. An added benefit is that it makes using any scan tool a bit more convenient.
https://www.amazon.com/s?k=obdii+ext...nb_sb_ss_i_2_6
Old 07-26-2019, 01:37 AM   #10
Garandman
Garandman's Avatar
Compared the two plugs, I’ll get pictures. If you drew a line from the top outermost pin to the bottom, on the one that fits, the fin in the center ends on the line.
On the Autel cable, the fin ends just outside the line. Haven’t done any measurements yet but it looks like trimming each side a little bit will help it work.
The Following 2 Users Say Thank You to Garandman For This Useful Post:
Aqua Puttana (07-26-2019), DesertAdventures (08-13-2019)
obd, scanner, sprinter 2006, t1n
