Old 04-06-2019, 08:00 PM   #1
thomasrobert23
thomasrobert23's Avatar
Default Conductor plate removal emergency
So Iím starting a new thread rather than contribute my P0715 error code thread
So changing the 13 pin connector and cleaning TCM worked for a day, I drove 200 miles
Delivered my job then it went into LHM with same trans code. Stopped 5 times to reset and finally it got me home thank god. So now taking off pan to take of valve body and put on new conductor plate.
So far so good until I got every valve bolt loosened and the last one totally stripped out
Need advice to get it out. Typically I would use a grinder to grind a line into it and use a flathead. Problem is Iím looking at a dripping valve body and after looking up trans fluid being combustible Iím not sure how to proceed. Sparks laying under van sketchy enough but fluid that might catch fire I am stumped.
All I can think is to cover the valve body with something to shield from sparks with a cut out where the bolt is ? Iím really stumped and bummed because I was so excited to finally replace the conductor plate to see if it fixes this problem. I have 5 days to get this thing back on the road any and all help appreciated.
File Type: jpg 680BAFF3-7566-4753-B05F-52BFB05A385C.jpg (116.7 KB, 74 views)
thomasrobert23 is offline   Reply With Quote
Old 04-06-2019, 08:06 PM   #2
thomasrobert23
Default Re: Conductor plate removal emergency
I sprayed with blaster but it will only help if I can get some torque on it.
Also looking to find new valve body bolts to replace in the end. Couldn’t find on a search for
A dodge 2006 2500. ?
Old 04-06-2019, 08:07 PM   #3
thomasrobert23
The culprit. See pict
File Type: jpg E95998B3-3787-4292-91DD-E965FAD15847.jpg (103.8 KB, 88 views)
Old 04-06-2019, 08:23 PM   #4
Is that a hex socket, or a Torx?
Either way, sometimes i grind a next-size larger Allen wrench to have a "conical" (i.e. faces of hex are slopes) tip and then pound it in.
I'll frequently use a metric to give me an intermediate size in an SAE socket, or an SAE wrench to provide the intermediate in a metric.
outbound (04-06-2019)
Old 04-06-2019, 08:24 PM   #5
thomasrobert23
It’s a T30
Old 04-06-2019, 08:27 PM   #6
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Hacksaw, no sparks involved!
36,000 miles from New
Old 04-06-2019, 08:37 PM   #7
thomasrobert23
I’ll see if I can find a small hacksaw Do you think epoxying a t30 bit into it and letting it harden would give enough grip ?
Old 04-06-2019, 09:18 PM   #8
thomasrobert23
A friend bringing a screw extractor tomorrow. Will try that.
Does anyone know where I can order trans valve bolts ?
Old 04-06-2019, 10:03 PM   #9
MillionMileSprinter
Formerly Type2Teach
MillionMileSprinter's Avatar
Did you try tightening down a vice grip pliers over the head of the bolt and trying to loosen it? I find that sometimes works.
Sprinter Mechanic
Joel Sell
For HELP, SERVICE and MORE
MillionMileSprinter is online now   Reply With Quote
The Following User Says Thank You to MillionMileSprinter For This Useful Post:
Zundfolge (04-06-2019)
Old 04-06-2019, 10:41 PM   #10
outbound
06/2500/140
i 2nd --dick's method/theory.
(use an 'adjusted' allen wrench, pounded-in to the bad torx)
outbound is offline   Reply With Quote
t1n
