Old 06-15-2018, 10:00 PM   #21
Justchillinout
Default Re: H7 LED Headlight Conversion Kit - Anyone Tried?
Sometimes being in Canada really sucks. How is this for a conversion rate?
Justchillinout is offline   Reply With Quote
Old 06-16-2018, 11:37 AM   #22
Patrick of M
2005 T1N 2500 (NA spec)
Just go direct to the source (all this stuff is made in Asia anyway).
https://www.aliexpress.com/wholesale...rchText=h7+led
Patrick of Montreal
2005 T1N (NA spec).
Justchillinout (06-26-2018)
Old 06-19-2018, 01:21 PM   #23
PATECO
PATECO's Avatar
Here are pictures of the steps to install them. These bulbs were nice in having a removable collar so that they went into the bulb holders quite easily.
  1. Unplug and remove the old bulb.
  2. Remove collar from the new bulb.
  3. Insert locking collar into bulb holder and re-attach retaining clip.
  4. Insert new LED bulb into locking collar.
  5. Plug in and test.
2004 Freightliner 2500HC Short/Short Cargo
PATECO is offline   Reply With Quote
Old 06-19-2018, 01:22 PM   #24
PATECO
PATECO's Avatar
Here are pics with one LED installed, and then with both.
The Following 2 Users Say Thank You to PATECO For This Useful Post:
aldsmith3 (12-12-2018), odix@yahoo.com (02-03-2019)
Old 06-19-2018, 01:29 PM   #25
DRTDEVL
I look forward to see how they perform at night. Are you replacing the highs, too? Anything I can do to make my van safer for my driver is of the utmost importance.
2004 T1N FedEx spec, slowly adding creature comforts, quickly adding miles. Currently at 373,000 miles (6/18).
DRTDEVL is offline   Reply With Quote
Old 06-19-2018, 01:33 PM   #26
PATECO
PATECO's Avatar
I live in an urban area, and rarely use the highs. I have yet to need to replace a high beam bulb. while the low beams were only lasting a few months. I decided that the next time one of them went I was going to go LED. That happened a week and a half ago. I will let you know what I think the next time I drive at night.
Old 06-21-2018, 04:22 PM   #27
PATECO
PATECO's Avatar
Just a heads up.
When I installed the first bulb, I was not super impressed with the light pattern and brightness. You can see in the picture below, that I had the bulb installed with the heat sink horizontal. After installing the second one, I realized that this put the LEDs facing up and down instead of side to side. I rotated both bulbs, and now the light pattern is excellent, and they provide much more light. In the pictures below, you can see how horizontal the pattern is, and how it lights the road, and not the overhead trees. When I was standing in front of it, it caused a lot of flare in the camera lens, but was not blinding to my eyes
The Following 5 Users Say Thank You to PATECO For This Useful Post:
glasseye (06-22-2018), Greendinosaur (01-06-2019), PortlandSprinterConnection (07-31-2018), SD26 (11-01-2018), TheMFVan (07-31-2018)
Old 07-31-2018, 04:05 AM   #28
TheMFVan
Just put in an order for them! $36 isn't half bad and a bulb died on me today. Hopefully this is the solution to our DRL equipt vans.
Newly purchased 2005 118" 2500 Cargo.
Resident newbie researching for that #vanlife
TheMFVan is offline   Reply With Quote
Old 07-31-2018, 10:19 AM   #29
Perce
What LED bulb would suit the high beam?
Perce is offline   Reply With Quote
Old 07-31-2018, 02:45 PM   #30
PATECO
PATECO's Avatar
High Beams use an H1 bulb
BEAMTECH H1 LED Headlight Bulb, 50W 6500K 8000 Lumens $36.99
However, I have not tried these, and don't know if they will work with the high beam retaining ring, or fit behind the back cover.
headlights, t1n
