Go Back   Sprinter-Forum > Regional Discussions > Europe
Old 10-20-2016, 11:13 AM   #1
bellie
Default 2nd gear problems
hi guys
( 57 plate 311) when i change from 1st into second it clunks, occasionally 2 nd to 3 rd ive just had the clutch kit and flywheel done thinking this might have been what the problem was but it still does it ....anybody else had this problem
thanks
bellie is offline   Reply With Quote
Old 10-21-2016, 04:50 PM   #2
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Default Re: 2nd gear problems
Hi Bellie,
Seen as no one else has replied I'll try and give you some things to try for starters.
Do you have excessive play in any of the U/J's in your propshaft?
Is there excessive backlash in your diff?
Has your axle come loose on the springs? (Dennis's favourite 'wheel tappers and shunters' comment).
Keith.
PS You are obviously in the UK (57 plate gave it away) but whereabouts?
36,000 miles from New
lindenengineering (10-23-2016)
Old 10-24-2016, 03:50 AM   #3
lindenengineering
Originally Posted by Cheyenne View Post
Hi Bellie,
Keith.
Yes 57 plate tells me 2007 to 2008!
Anywhere near Gloucester?
My brother has a shop in South Gloucester area.
Keith remember being a Brit he is also automatically a Wheel tappers and Shunters club member as long as he doesn't bloody well start drinking halves of bitter or G n T's in the pub like them pufters in Lundun!
As for that Sprinter its probably lost its fulurum!
Sorry tiz the Irish in meh!
For our American members a glimpse of a typical working mans club (operative words here) & and Dubliners talking a frozen pee in the men's room! (A slash in the bog)
Cheers
Old 10-24-2016, 07:52 PM   #4
Tukala
Repair / Service
Tukala's Avatar
Hi,
Did they happen to change trasmission oils at same (with clutch & flywheel)?
Just crossed my mind that these 6-speed manual tranny┤s are somewhat Ęprecise" waht goes with oli level.
Don┤t have the manual with me now, but I think it was 1,2liters..
If "over filled", like to the edge of the "fill-point", gears will get clunking. Ecspecially from 1st to 2nd.
Tukala is offline   Reply With Quote
Old 10-27-2016, 06:39 PM   #5
stroud_omnibus
It could also be the linkage was 'disturbed' when the gearbox was removed and not aligned properly when re-installed. I had this problem a couple of months back when I had my clutch done. No clunking but problems getting into gear.
Ended up replacing some of the linkage and the ball-joint type connectors at the end of the selector cables. Along with new oil it's all good except I think there may be a noisy bearing in the 'box so it may well be back out again in the not too distant future!
Alan
2006 413CDI, 16 seat minibus
based in Great Britain
stroud_omnibus is offline   Reply With Quote
