Old 09-29-2010, 04:49 PM   #21
johnnydrz
Default Re: Onan Generator, problem...
Hi everyone, I have a new-for-me 2005 RS Adventurous. The generator runs fine but I don't have any power inside the RV... I know there is a 5 AMP fuse (checked it) and a breaker next to it (tripped it repeatedly...) but still no power inside. In the book, there is no mention of anything else related to the genset power feeding the RV. Where should I measure the input voltage to the electrical circuit? I don't want to go to an RV place just so they can suck an insane amount of money just to tell me it's something I could have checked and fixed...
Thanks in advance,
Johnnydrz
johnnydrz is offline   Reply With Quote
Old 09-30-2010, 12:55 PM   #22
mike_mcginn
mike_mcginn's Avatar
Check for a transfer switch. Your generator voltage
should be present there even if it does not work.
Also check it with shore power.
Thanks in advance,
Johnnydrz
mike_mcginn is offline   Reply With Quote
Old 09-30-2010, 03:28 PM   #23
boatmax
Good advise; they do burn out, and there should have been smoke and a hot electrical smell, as I had in an old class A RV.
Max
boatmax is offline   Reply With Quote
Old 10-06-2010, 01:18 PM   #24
johnnydrz
I don't know where the transfer switch is... I have no documentation that shows where it should be...
Old 10-06-2010, 08:16 PM   #25
mondmn70
I would go to one of the Roadtrek sites such as in Yahoo Groups and post the question.
mondmn70 is offline   Reply With Quote
Old 10-06-2010, 08:50 PM   #26
boatmax
It should be a small gray box, where both generator wiring and shore power wiring enter the box, with one set of 120 Volt wiring coming out the other end. The box senses a power source and switches to it, taking shore power over generator power, when it senses both.
Max
Old 10-13-2010, 03:58 PM   #27
johnnydrz
Boatmax, swapped the transfer switch last night, fixed the problem! It is located in the rear passenger side, where the bed is.
Johnnydrz
Old 01-13-2011, 12:07 AM   #28
icarus
The transfer switch in the RT is in the left rearwell, next to the furnace.
Old 01-14-2011, 02:07 AM   #29
Trekker
Trekker
Trekker's Avatar
It's been 3 and a half months. If you haven't solved this yet,check the reset switch on the Onan. It's a breaker built into the genset. You have to crawl under the van and remove a panel on the Onan, the push the reset button to reset the breaker. Check your owners manual.
2018 Roadtrek Agile Eco-Trek
The Following 2 Users Say Thank You to Trekker For This Useful Post:
brassarl (03-14-2011), slowstride (03-02-2011)
Old 01-14-2011, 02:56 AM   #30
icarus
A quite common problem with small generators is the spark arrestor screen in the exhaust gets plugged with carbon. This can cause hard starting, sluggish performance and stalling especially under load. Onan recommends cleaning the screen every 50 hours and I would bet that few people do it, as you have to remove the exhaust at the generator.
Partial causes of plugging are poor fuel, running with lights loads, cold starts, wrong heat range plugs, excessive lugging etc. This tends to be less of a problem in L/P generators than gasoline fueled engines.
Icarus
The Following User Says Thank You to icarus For This Useful Post:
