SubForums: Events Scanners
Old 05-28-2019, 08:25 PM   #3781
BrennWagon
Pete
Default Re: What did you do to your Sprinter today.
Today I put on a leather steering wheel cover which came out better than I expected.
AULLY PARK Universal Genuine Leather Car Steering Wheel Cover Stitching Style (Size M, Gray) https://www.amazon.com/dp/B018FM55UE..._kIz7Cb2GCGDPZ
I also added weather stripping to the outside edges of the drivers door
BrennWagon is online now   Reply With Quote
The Following 3 Users Say Thank You to BrennWagon For This Useful Post:
Aggie (05-29-2019), Garandman (05-29-2019), Larms (06-26-2019)
Old 05-29-2019, 05:13 AM   #3782
Garandman
Garandman's Avatar
Awesome! Wanted to order a wheel wrap but wasn’t sure about fit.
Replaced the interior cargo lights with 800 Lumen (claimed) LED’s. 42mm Festoon style. Four for $8.
2006 Sprinter 118 ~ 16 Rial Transporter rims ~ 235/65x16
Old 05-29-2019, 06:41 PM   #3783
ranchworld
'06 158 2500 Passenger
Hey Brennwagon, what weather strip did you use? Has it made a difference in noise?
Thanks.
I also added weather stripping to the outside edges of the drivers door[/QUOTE]
Old 05-29-2019, 09:22 PM   #3784
BrennWagon
Pete
Thanks.
[/QUOTE]
I used Metro Sponge Supersoft brand 7/8x3/4x8 bulb style weather strip. $19.99 at Autozone. To answer your other question, it helps immensely
ranchworld (05-30-2019)
Old 05-29-2019, 09:31 PM   #3785
BrennWagon
Pete
I finished the rough installation of a shelf above the sun visors. Im planning on eventually mounting a small TV in the center so Im going to build an enclosure to surround the dome light hole with a flat blank space for a 10 monitor. The shelf is made of scrap pegboard, a piece of aluminum storm window frame as the lip, covered in thin foam, wrapped in vinyl cloth, and painted to match the interior. I went with kinda flimsy materials so that in the case of an accident it will break before bones. I made brackets to utilize the sun visor mounting screws and angles for the sides.
Old 05-30-2019, 09:18 PM   #3786
BrennWagon
Pete
Built a center console for my new shelf. The body is made from layers of cardboard laid perpendicularly and glued with spray adhesive. Its makes a surprisingly strong but safe structure. Now all I need to do is lay some felt on the top of the actual shelf. I made it so that it could eventually hold a 12 flat screen TV. Theres a bit of a gap on the bottom that I need to fill, eventually. One of these days Ill do a technical write up on upholstering home made add ons like this and building with cardboard, particle board, and foam
Old 06-01-2019, 10:05 AM   #3787
Mickyfin
Mickyfin's Avatar
Today I fit my fresh water tank to the underside of my van. Quite straight forward. Next jobs are to carry out the body penetrations, just waiting for some decent weather as its blowing a gale out there today 50+mph winds.
Untitled by S STEEL, on Flickr
The Following 3 Users Say Thank You to Mickyfin For This Useful Post:
BrennWagon (06-01-2019), ranchworld (06-03-2019), Surveillance Van (06-01-2019)
Old 06-01-2019, 10:52 PM   #3788
sassmatt72
2006 low top 10 pass
What tank is that, and where did you get it??? thx
I'm back!
sassmatt72 is offline   Reply With Quote
Old 06-02-2019, 02:06 AM   #3789
mtncrawler
Trimmed out the slider step and rear floor edges...the cardboard is my future ARB 50QT Cooler..
mtncrawler is online now   Reply With Quote
The Following 2 Users Say Thank You to mtncrawler For This Useful Post:
Mickyfin (06-02-2019), ranchworld (06-03-2019)
Old 06-02-2019, 02:24 AM   #3790
DewMan
DewMan's Avatar
Looking like a quality build! I'm jealous.
Where's the build thread hiding?
Thank you for your time and attention,
DewMan
Too old for Twitter and too young for Life Alert.
DewMan is offline   Reply With Quote
