SubForums: Events Scanners
Old 05-19-2019, 09:06 PM   #3751
JFloFoto
Default Re: What did you do to your Sprinter today.
Cleaned the EGR valve at 33k miles. PITA to get out... Took a lot of wiggling and niggling, but it came out and service was done in situ w/o removing coolant lines. I think this is a must ~ every 30k miles.
Sent from my Pixel 3 using Tapatalk
The Following User Says Thank You to JFloFoto For This Useful Post:
Mickyfin (05-20-2019)
Old 05-20-2019, 02:49 AM   #3752
BrennWagon
Pete
Tonight I added a switch that allows me to power my stereo and amp without a key in the ignition (jumper from cigarette lighter positive to radio acc wire). Also put together a tray to add an aux battery under the passenger seat
File Type: jpg 43F2687E-7A64-453A-9B30-FEC57602DE33.jpg (88.4 KB, 159 views)
BrennWagon is offline   Reply With Quote
Old 05-20-2019, 06:19 PM   #3753
BrennWagon
Pete
Today I put almost a gallon of bedliner on my roof. I may be painting it to match the body soon but Iím definitely keeping the gutter black
File Type: jpg FA98E43B-1A11-469D-A3AC-3126869C5EC1.jpg (145.0 KB, 151 views)
File Type: jpg DB190DE9-B5FF-4DFC-AB8D-62CA298FE9DC.jpg (146.3 KB, 143 views)
File Type: jpg 7720EB81-43F8-4EB4-81CB-245F1477ED74.jpg (149.4 KB, 141 views)
Old 05-21-2019, 01:45 AM   #3754
jcmadeintheshade@gmail.com
BrennWagon, thanks for the photos. Looking good.
We both have silver/gray vans and I am considering finding a gray bedliner product.
Some of the bedliners bubbly texture bothers me, as I would prefer a smoother finish, especially the kevlar based headliners that I have seen. I like the idea of Kevlar, but the lumps look more than any of the products I have seen. The smoother the better for me.
Did you roll it on or buy the spray cans, or use a spray gun?
As with a lot of detailed work, it is all in the prep time spent and your efforts show the extra effort.
The on the road noise mitigation is an additional plus of covering our vans with bedliner.
Which product did you use? Thanks.
The Following 2 Users Say Thank You to jcmadeintheshade@gmail.com For This Useful Post:
bconley (05-24-2019), Sprinter Bob (05-25-2019)
Old 05-21-2019, 04:48 AM   #3755
BritzSprinter
Ex Britz 313CDI Motorhome
Got the windows tinted, 35% front doors, 5% for the sides & rear.
No more having to close the curtains to nude up
BritzSprinter is offline   Reply With Quote
Old 05-21-2019, 10:39 AM   #3756
Garandman
Garandman's Avatar
What did you use to clean it?
2006 Sprinter 118Ē ~ 16Ē Rial Transporter rims ~ 235/65x16
Old 05-21-2019, 10:46 AM   #3757
Mickyfin
Mickyfin's Avatar
My x 5 new BFGoodrich KO2's arrived today so will be getting those fitted to my freshly powder costed OEM alloys soon, pumped! Pardon the pun!
Old 05-21-2019, 10:59 AM   #3758
JFloFoto
Brake cleaner, tooth brush, and Q-tips.
The Following 3 Users Say Thank You to JFloFoto For This Useful Post:
israndy (05-21-2019), Mickyfin (05-21-2019), sassmatt72 (05-21-2019)
Old 05-21-2019, 09:22 PM   #3759
BrennWagon
Pete
The on the road noise mitigation is an additional plus of covering our vans with Bedliner
I used Herculiner on the black parts. Itís said that they make gray and white colors too but good luck finding them!! I rolled/brushed it on and itís said that you can strain out the rubber grains for a smoother finish. It does mitigate a fair amount of road noise but itís the rust protection Iím after more than anything else. Form follows function, and I go on the roof enough that a non skid surface is helpful, plus this way I donít feel like I need to put decking on the roof rack. The paint is an ongoing process, itís Rustoleum Aluminum oil based paint that I rolled 6 coats on after extensive rust treatment. Iím slowly wet sanding the whole thing to prep for a final base and clear coat. And Iím putting stripes down the sides once the base coat is finished. The paint has held up extremely well, prep work is everything and a final wipe down with xylene really helped the silver bond with the factory paint and primers.
Old 05-21-2019, 11:06 PM   #3760
mtncrawler
I'd be interested in more details on this. I'd like to power my stereo and amp (both aftermarket) from my house batteries for camping. Maybe not quite the same setup - maybe some type of switch where the stereo/amp draws power from main electrical when the van is running and then a switch to draw from house when not.
mtncrawler is offline   Reply With Quote
The Following User Says Thank You to mtncrawler For This Useful Post:
