Go Back   Sprinter-Forum > General Forums > The Competition
The Competition Discussion of other vehicles similar to the Sprinter; Transit, Promaster, etc.
SubForum: Write-Ups
Old 04-23-2019, 03:36 AM   #1
Trick
Default 2019 models: 3.5 Ecoboost, 3.2 Powerstroke I5 or Mercedes 3.0 V6
Time for a van upgrade. I Currently own a 2004 & 2005 Sprinters. One is 290k miles and lots of rust. The other is 190k miles and medium rust. I use the van for work, loaded with appox 2000lb of shelving and tools and drive approx 80 miles a day. I also tow an enclosed trailer weighing just under 5000 lbs a couple times a month.
Doing research many are saying the current diesels are not worth the extra maintenance & repair costs. Which I understand it can be a bit more pricey. But what about life expectancy?
Is an EcoBoost going to fail very close to 150K miles while a Diesel will often go 300+k miles?
IDK and I havent found anything on the interwebs to help.
I think MPG is about the same on all 3 of these motors, very close to 16mpg.
What do we think of this and what is the best choice for me and how I use my van? (2019 Sprinter 3.0 V6 Turbo Diesel, 2019 Transit 3.2 I5 or a 2019 Transit 3.5 V6 EcoBoost)
I also don't plan to sell it after so many years or miles. I would drive it till the wheels fell off or it rusted out, which ever comes first.
2004 Sprinter, 2500 SHC. 270,000 miles. (Toy hauler & backup work van)
2005 Sprinter, 2500, 120,000 miles. (Primary work van)
Trick is offline   Reply With Quote
Old 04-26-2019, 10:40 PM   #2
The Grand Tour
Banned
Default Re: 2019 models: 3.5 Ecoboost, 3.2 Powerstroke I5 or Mercedes 3.0 V6
The Sprinter 2500 vans will tow 5,000 pounds, and have a payload capacity of nearly 4,000 pounds, so there is one other Mercedes-Benz engine to consider- the M274 turbo 2.0 4-cylinder gas engine.
And Ford has had problems with the turbos on the twin-turbo 3.5, but they are going to replace the 3.7 with a non-turbo 3.5, so you will be able to have a 3.5 without the turbo headaches.
And finally, Ford is going to replace the 3.2 turbodiesel with a more-powerful twin-turbo 2.0 diesel 4-cylinder, so that would be an option for you as well.
Any of those engines would work for your application. Just keep in mind that gasoline tends to be less expensive in the U.S. than diesel fuel, so even if a gas engine delivers less miles per gallon, it may still be less expensive to feed.
The Grand Tour is offline   Reply With Quote
Old 04-27-2019, 12:02 AM   #3
Graphite Dave
Dave Orton
All modern diesel engines have complicated emission systems no matter what brand.
Drive the vehicles to help make your decision.
Old 04-29-2019, 12:44 AM   #4
Garandman
Garandman's Avatar
We had a 2015 Transit with EcoBoost. It would tow 5,000 lbs like it wasn’t even there. The diesel was about $3,000 more and had similar tow rating. Our negative experiences with diesel emissions control was another reason we bought the EcoBoost.
Originally Posted by The Grand Tour View Post
And Ford has had problems with the turbos on the twin-turbo 3.5, but they are going to replace the 3.7 with a non-turbo 3.5, so you will be able to have a 3.5 without the turbo headaches//
Citation needed.
The 3.5 EcoBoost has been in F150’s since 2011. There are literally millions on the road with many, many high mileage examples.
Not to mention 5X the number of dealers.
Originally Posted by therabbittree View Post
Gm offers the 2.8 diesel in the express and savanna vans in 2wd models your (sic) looking 26-29 mpg
Got facts? Our V8 Express averaged around 15mpg and the best tank we ever got was 18. In our use diesels got 20-25% better mpg, not 60-70%.
2006 Sprinter 118 ~ 16 Rial Transporter rims ~ 235/65x16
Old 04-27-2019, 01:54 PM   #5
danski0224
If I'm in a position to buy a new van again, it is doubtful that a diesel engine will be under the hood. Unless the van I want isn't available without a diesel, and that may require a reevaluation of why I want that particular van.
Additionally, based on my experience with Sprinters and rust, it would take a lot to go down that road again.
danski0224 is offline   Reply With Quote
Old 04-27-2019, 04:41 PM   #6
therabbittree
Gm offers the 2.8 diesel in the express and savanna vans in 2wd models your looking 26-29 mpg
therabbittree is offline   Reply With Quote
Old 04-28-2019, 04:15 PM   #7
DRTDEVL
Is there a reason you are avoiding the Ram Promaster 3.6 Pentastar? I have spoken with several expediters that have over 400k on the odometer with no complaints.
2004 T1N FedEx spec, slowly adding creature comforts, quickly adding miles. Currently at 373,000 miles (6/18).
DRTDEVL is offline   Reply With Quote
Old 04-30-2019, 05:06 PM   #8
Trick
I stopped at the local dodge dealer and they said they didn't have any I will look into it further.
Old 04-29-2019, 01:04 AM   #9
ENMeyer
When I was considering the Ford Transit, I wanted the Powerstroke diesel, but figured I'd skip the possible headaches of the diesel and go with the EcoBoost. Just a slight upcharge from the base 3.7L engine, and about the same fuel economy, but gobs more HP and torque. Why not?
I did test drive a base 3.7L as a rental for 3 days and 1000 miles and that 3.7 wasn't a bad engine. Nothing about it made it feel special, but it did it's job and had enough power.
2016 ///AMG Silver HR Crew I4 for work / play
ENMeyer is online now   Reply With Quote
Old 04-29-2019, 02:54 PM   #10
asimba2
2016 4cyl High Roof 144
asimba2's Avatar
Given your use case my order of preference would be:
1) 2014-2016 Sprinter with the 4 cyl diesel (not sure if you're willing to buy used)
2) 2020 Transit with the 4 cyl diesel (not available quite yet, can you wait?)
3) Sprinter V6
I wouldn't buy an Ecoboost V6 until Ford puts the Gen2 version in the Transit like they have the rest of their lineup. Gen2 includes dual injection to avoid the valve carbon deposit problem.
I'd shy away from the 3.2 Transit diesel....they didn't sell very many and repair may be an issue in the future. I think it's smart to not consider the Promaster at all.
asimba2 is offline   Reply With Quote
