My 2002 Freight Liner is exhibiting the following issues:
Fuse box 1:
Fuse 1 blows when light switch is turned on.
Fuse 9 blows when inserted.
Fuse 10 blows when light switch is turned on.
Fuse 11 blows when light switch is turned on and engine is running. Does not blow when ignition is off and light switch is turned on. Does not blow when ignition is turned to on and engine is not started. when fuse does not blow front and rear running lights work.
Dash lights come on when ignition switch is on and engine is not started but go off when engine is started.
Transmission is in limp mode - the issue began when the sprinter first blew the fuses. The Dash light issue has been ongoing since I purchased the van this summer.
I do not have a mercedes sprinter code reader.
I have replaced the fuse box (due to another issue). Yes, battery was disconnected during replacement.
I have replaced the multifunction switch. Yes, the battery was disconnected during the procedure.
has anyone experienced some or all of these issues? Can anyone provide guidance to solve the problem, short of a complete rewire of the van?
New to the forum and tried to find a thread on this - found several close but not presenting quite the same.
I am not a mechanic, nor an engineer but will do my best to answer any questions you may need to help diagnose this issue. Please remember that I will not understand many acronyms and professional words, abbreviations and phrases. I am not stupid and can follow instructions, just not experienced in the field of mercedes sprinters. Please respond in plain english. Thank you in advance.
Fuse box 1:
