russinthecascades
I installed both d-side and p-side Eurocamper swivels without any alignment problems. E-brake adapter also went in without problems. But it would be nice if the sharp corners were machined for rounding...
I am very interested in getting OEM swivels for my 2018 2500 170" high roof Vin# WD3PE8CD3JP599752Camping,
After you check out all the "aftermarket" options, why not just order the correct seat swivel/bogie from your nearest authorized Mercedes Benz Sprinter
dealer.
Almost guaranteed to fit, passed all the crash and passenger safety tests, works perfectly....and probably only cost a few dollars more.
Send me your VIN # by PM (above to the right at the top) and I'll pull up the part number for you.
Send me your VIN # and a valid return email address and I'll return your new Sprinter complete build data card!
Roger
Yes but the title of the item is "Brand New sprinter Seat swivel 2002-2019"Did you notice it says it fits Mercedes METRIS??
Just got one of these bases
https://www.ebay.com/itm/Brand-New-sprinter-Seat-swivel-2002-2019-fits-mercedes-metris/193067747228
Hopefully it works well and matches up fine with my 2005 2500 on the passenger side. After reading this whole thread this seemed like the best design I could find with the off set swivel, and the lack of rollers.
Does anyone have experience or knowledge about these, I know it was a shot in the dark, but work a shot.
I just received and installed the base today. The quality is pretty top notch; Stamping, welts, and fitment is really good. The alignment is pretty interesting, as the base is about 1" wider than the stock base in the vehicle, and the seat mounting plate itself (I will post a picture or two of this later). The construction is pretty smart as the swivel is just based around the stamping outer plates and a sandwich of nylon (at least from what I can tell) plates. So all of the movement is just friction based, with no bearings or rollers of any kind. It is very smooth and I will assume now that it should not get sloppy over time, but instead probably bed in and become smoother. The locking mechanism is as simple as simple gets, and there are notches for a few different positions (Front, 180*, and 45* side to side from backwards.) there is a small amount of play side to side when the seat is locked into place, but not much and it does not seem unsafe in any way.
The only hiccups on install were a lack of hardware and the seat belt attachment. Luckily I work for a bike rack company, so we have M8 hardware galore and I was able to scrounge up the additional 6 bolts, 6 nylock nuts, and 12 washers I needed to install. As far as the seat belt goes, most of the bases I have seen have an additional plate to attach the seat belt to, and I was worried for a second when I noticed this one did not. However, on my factory pedestal there was a threaded hole that matched the threads and it was just about perfect placement for the bottom attachment point for the seat belt. Now it all functions perfect and you do not even notice.
Overall I would recommend the hell out of this base, especially because the mechanism is so simple, and the price is right compared to the alternatives. I will post some photos later on.
Ahh yes. This is a different model that what I purchased along with ‘joeyearly’ above on the post. It is this one https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/193067747228
Your link I heard is the best one rated by faroutride.com. I believe it includes the proper parts as well. Grant it, another $100 than what I paid, but I guess that is the irony of this whole thread to begin with ����♂☺
Ended up purchasing the Scopema swivel for the passenger side (from link in my earlier post). Install was pretty easy - just had to cut the plastic bottom seat trim to allow swivel. Overall it raised the seat about .8" (as advertised). Mechanism seems smooth, but I'm a little concerned about the amount of "wobble". Looking more closely at the design - it certainly has a smaller diameter contact area (compared to others) which contributes to this. Locks in place pretty solid - but there are no other locking points along the rotation - which may have been nice.Hmm, you know I didn't catch that. I thought I was following the same link in 'joeyearly''s post, but I must have wandered through a series of links to the one posted.
Now I see the diff - I may go ahead and try the more $$ one - at least for one side.
How did you trim the skirts on the seat and is the cut clean? This task is on my list and I am thinking to use a small 3-3/8” circular saw, the cut could be cleaner than from using a jigsaw.Ended up purchasing the Scopema swivel for the passenger side (from link in my earlier post). Install was pretty easy - just had to cut the plastic bottom seat trim to allow swivel. Overall it raised the seat about .8" (as advertised). Mechanism seems smooth, but I'm a little concerned about the amount of "wobble". Looking more closely at the design - it certainly has a smaller diameter contact area (compared to others) which contributes to this. Locks in place pretty solid - but there are no other locking points along the rotation - which may have been nice.
We'll see how it works and rides once I get it out on the road!
Just marked a straight line on the plastic skirt using a sharpie - then used my aviation (sheet metal) snips to cut. The cut line was mostly clean -some jagged spots - but I have some nice course rasp files that I used to smooth/straighten the cut edge. Came out well - took 15 minutes to do both sides.How did you trim the skirts on the seat and is the cut clean? This task is on my list and I am thinking to use a small 3-3/8” circular saw, the cut could be cleaner than from using a jigsaw.
