Wrong! You neglected the Peukert effect. A battery bank rated at 220 ah can draw 11 amps for 20 hours. If the draw is more than 11 amps, the capacity will be less than 220 ah.Batteries are rated in amp hours or watt hours.
What that means is if you have a 2400 watt hour storage (that is what 2 6V AGM in the CS Adventurous has standard) You can have 240 watts per hour over 10 hours or 2400 over 1 hour. You need to be careful on understanding the rating is in watt (or amp) hours.
My CS Adventurous has 4 6V AGM for 4800 watts.
20 hour rating would be equal to 120 watts per hour. You just need to be careful.
I installed a volt meter which plugs into one of the DC sockets to monitor voltage. Minimum AGM charge is around 11.8 volts.
Len
we have a 2015 SS Agile w/ 4 cylinder......Can you let me know what is the "real world" diesel mileage of your 4-cyl Agile?
thanks,
2011 Agile
hi starfighter,we have a 2015 SS Agile w/ 4 cylinder......
after 9,000 miles our average has been 23 to 29 mpg
23.4 with cool weather, some elevation changes and some head wind.
29.5 in warm weather, no wind, flat travel.
(best mileage seems to be at 58 to 61 mph)
