Old 05-22-2011, 04:47 AM   #1
sikwan
06 T1N Can
sikwan's Avatar
Default Power Window Track Fix
A compilation from two threads.
Bending the Arm and Lubrication.
Originally Posted by cacaw View Post
Edit: got it done with a small zip tie around the plastic piece that broke. But after bending the arm, the zip tie is superfluous - the arm is now pressing tightly into the track on its own accord and there's no way it's going to come out of the track.
If not bent in enough apparently a slammed door can knock it loose.
Originally Posted by jcmadeintheshade@gmail.com View Post
I bought the replacements and realized I needed to drill out the remaining broken part in the actuator arm. Forgive the lack of accurate terminology. Time was short, so I slightly bent to arm enough to keep it in the track and with a little lithium grease, away I went.
The only time it has popped out was when a mechanic slammed the door. That was a one time lesson. These doors do not have to ever be slammed shut. If I ever feel so inclined, I will drill out the offending piece and install the Ebay piece. Bouncing around Baja last winter did not affect this temporary fix. Only a careless mechanic has caused me to go back in there and push it back into place.
Originally Posted by ohlsonmh View Post
After reading a lot of things here & on Youtube, we just bent the arm toward the outside of the door - it's pretty springy so we put a block of wood behind it & then used a pipe-wrench for leverage and bent it so that it holds the stud in the window-bottom track where the broken plastic slide used to be. The window rides up & down on the stud, rather than a 'fancy' slide.
Works great. No cost. Hardest part was getting the door panel back on.
-Oly
Lubriplate is an excellent choice.
I used regular old *modern* wheel bearing grease to lube the 2004 and 2006 tracks. In my experience modern wheel bearing greases do not dry out or harden.
If the tracks are periodically lubed, I see no reason that the bend the arm trick and using the metal button only won't be good. The T1N's are old. A greased metal button as a slide will outlast the service life of an old T1N.
Lubing the tracks isn't difficult.
Lube Grease Window Track and Parts
https://sprinter-source.com/forum/sh...ad.php?t=75849
I trust that Sikwan won't mind me adding this T1N window regulator quick fix Youtube video here.
Basically.
Remove top pillar trim by pushing/tapping the lower section toward the vent window.
Remove the pull handle cover trim.
Remove switch assembly and unplug connectors.
Find 2 ea. T30 screws and remove. (One is in a deep and narrow recess.)
Unlatch lower storage hatch and swing open.
Grasp door panel and pull straight up to release clips.
For driver side power window:
Struggle to release the switch connectors past the latch cable.
For passenger side power window:
Easily work the single connector free past the door latch cable.
For lubing I just balanced the door panel on the open hatch door. More extensive work might require freeing the latch cable to completely remove the panel.
Bend the operating arm in enough to get the actuator stub to engage the track.
Re-assemble in the opposite order.
Sikwan's original thread begins here.
A couple weeks ago I heard a rattle coming from the passenger side door. I've never heard it before so I just powered the window up and the noise went away. 15 minutes later when I parked the van, I tried to close the window but it wouldn't move. It would move up a bit, but it wouldn't go back down. Great, another thing to fix before the trip. Hopefully it won't be too hard.
Here's some info on removing the door panel...
http://sprinter-source.com/forum/sho...36&postcount=4
This is what I found when I removed the door panel...
The white plastic in the window channel split into "a" and "b" leaving "c" disconnected.
I measured the plastic piece and it was 0.625 in height.
I found a post from Vic (Thanks Vic!) that someone used a shower door roller that was 0.625 in height to fix the power window problem. Problem was I could not find any 5/8" roller at any of my local hardware stores. I had to order a set online from Home Depot and had them expedited.
When I got the roller, I went ahead and modified it with a Dremel and sanding bit. With the OEM (cracked in half) plastic on hand, I grounded the roller until it matched the original and it fit within the window channel.
Original roller, modified roller, and OEM plastic.
It was real close on the metal part.
Now to drill out the riveted part.
I laid a piece of cardboard down to catch the shavings.
sikwan is offline   Reply With Quote
The Following 19 Users Say Thank You to sikwan For This Useful Post:
AustinSprinterGuy (10-02-2012), Banister (06-21-2017), blessedmomof8 (11-03-2012), bpcustoms (04-15-2013), brassarl (05-17-2014), chop20041 (05-08-2012), darren (05-07-2012), hayduke (12-21-2013), ilsinc (04-11-2015), kalapis123 (07-02-2017), Kimcantri@gmail.com (10-24-2017), metaldirtart (08-13-2019), obbiedog (07-02-2012), PeterBrocks (09-15-2012), Reprographer (05-29-2019), rufus (03-21-2012), Speed Racer (07-18-2016), Thefwafwa (07-21-2016), TurboGus (06-09-2016)
Old 05-22-2011, 04:47 AM   #2
sikwan
06 T1N Can
sikwan's Avatar
Default Re: Power Window Track Fix
The pilot hole.
After a few different sized drill bits, I finally mangled the rivet off.
Before I attached the arm, I wanted to see if I could clear the track from rubbing against the piece of metal with the paint scratched off.
It was a wasted effort as it still rubbed. Plus I didn't want to dent the door outward. I wonder if there's a reason why the channel needs to rub against this part of the door. I don't think it's for alignment, but I could be wrong.
I removed all the OEM grease from the track and the arm.
I dripped some loctite red into the roller nut. I used 3 washers, the one you see under the head of an 8-32 (0.5" length) screw...
...and two on roller side. I tried one, but the arm would interfere with the channel.
The fixed window in action...
After I did a visual check that the roller would spin going up and down, I added some water resistant white teflon grease that I use for bicycles along the roller channel. I don't think it needed it due to the roller action, but I was worried about that thin piece of plastic that surrounded the roller backside metal.
I did the same for the driver's side since I had the extra roller. I like the roller method a lot more compared to the OEM version.
The Following 35 Users Say Thank You to sikwan For This Useful Post:
312d (05-09-2014), Aqua Puttana (05-22-2011), AustinSprinterGuy (10-02-2012), autostaretx (08-16-2011), Banister (06-21-2017), bpcustoms (04-15-2013), Bucket Boy (10-01-2012), CJPJ (12-07-2012), fisherman44 (12-09-2018), GPLYNCHBURG (02-09-2019), gregwoods (02-05-2012), Groovfunk (11-04-2019), H2Disco (08-11-2016), hayduke (12-21-2013), hkpierce (08-18-2011), Jsloane (05-24-2011), Kimcantri@gmail.com (10-24-2017), maxextz (08-16-2011), mendonsy (05-22-2011), MikeP (12-22-2012), Milton Demaray (01-08-2013), muki (08-28-2019), NetDoc (12-15-2015), NORTON (11-05-2013), obbiedog (07-02-2012), PeterBrocks (09-15-2012), rbarg (08-16-2011), Robtarus (05-30-2011), sarcel (03-31-2016), Sgt Ret (06-07-2013), shortshort (10-22-2013), Thefwafwa (07-21-2016), TurboGus (06-09-2016), wachuko (07-09-2019), yosprinter (09-02-2011)
Old 05-23-2011, 10:08 AM   #3
teamtexas
A Dad owner with a '03
teamtexas's Avatar
Great write up on the repair Seek! Looks like it operates smoother than ever.
Dan
teamtexas is offline   Reply With Quote
The Following User Says Thank You to teamtexas For This Useful Post:
sikwan (05-23-2011)
Old 08-16-2011, 01:36 AM   #4
rbarg
Thumbs up Re: Power Window Track Fix
Absolutely invaluable writeup on the window repair. The photos were super and the link to Home Depot made the roller purchase easy. The only change was I used 3 washers between the arm and the roller to make sure the arm cleared the track. Works wicked smooth. I should change out the passenger door soon. Thanks , Rich in CT.
rbarg is offline   Reply With Quote
The Following User Says Thank You to rbarg For This Useful Post:
sikwan (08-16-2011)
Old 08-16-2011, 12:31 PM   #5
maxextz
Rollin Rollin Rollin.....
maxextz's Avatar
thanks great stuff seek.
Sioux-316CDI/T1N/158/2005. Light Prevails
maxextz is offline   Reply With Quote
The Following User Says Thank You to maxextz For This Useful Post:
sikwan (08-16-2011)
Old 08-17-2011, 03:16 AM   #6
Dougflas
DAD OWNER
Local Lowes has them in stock.
Dougflas is offline   Reply With Quote
Old 10-21-2011, 06:04 AM   #7
Oregon2
Attachment 33426
Attachment 33422
Attachment 33423
Attachment 33424
Attachment 33425
sikwan, Fantastic window fix! I followed your instruction to the letter and it worked like a charm. I first sought advice from a Sprinter dealer who told me that in order to replace the nylon bushing I would have to replace the entire window regulator. The part alone was over $200. I found the 5/8" rollers at Ace Hardware. Had to buy a Dremel to shape the roller but this tool will come in handy for other projects including the passenger side window if that bushing fails. I used a Dremel grinding tool to grind off the rivet head and the rivet popped right off. Thanks again for the post. Oregon2
Oregon2 is offline   Reply With Quote
Old 11-04-2011, 11:16 PM   #8
Joes05VC
'05 Vista Cruiser fun trk
Joes05VC's Avatar
My driver's door window has dropped so far down that the bottom of the glass with the metal part for the roller cannot be seen. It is below the aluminum brace at the inside bottom of the door. The T-40 driver has messed up the head of the bolt and just turns. The big star-headed bolts must have been torqued to 200+ ft.Lbs. at the factory. Trying to pull the door glass up is futile because it is wedged so tightly between this aluminum brace and bottom of the door. I will have to grind the head off the bolt, pull the aluminum brace out and then maybe the glass can be moved up.
It is too bad that MB used so many plastic parts in the Sprinter that are subject to wear or breakage and are very difficult to access, fix or replace.
Sprinter Fun Truck
Joes05VC is offline   Reply With Quote
Old 03-17-2012, 05:54 AM   #9
pushingmetal
Thank you for this fix. I repaired the drivers door with this technique. My only concern is that the load is taken by an 8-32 screw rather than the stock rivet. How msny cycles do you have on the window since repair?
pushingmetal is offline   Reply With Quote
Old 03-17-2012, 06:54 AM   #10
hempaction!
WVO tour for hemp
Victory is mine! My first DIY project on this vehicle reminded me of working with my dad. Holding a flashlight while he cusses and fusses to make it work.
I ordered the part #74402 DOR from U.S. Auto Parts. It is the wrong size, but the Dremel is an amazing little tool. After shaving and shaving the plastic I realized that the metal roller was the right size for the track so I'm left with a pretty thin piece of plastic but the the roller won't come free of the track if the plastic breaks. I expect in that case the window won't roll as smooth and I will probably hear somethin funky comin from in there. Also the screw is bigger than the former rivet so I had to drill the hole out a little bit. So far, so good.
Best part is for the price of a couple of broken Dremel cutting discs (my first Dremel) I got to stick it to the dealer and MB who wanted over $300! The parts were even free because U.S. Auto recognized their mistake and is refunding my $$.
hempaction! is offline   Reply With Quote
