Hello,
I am selling a 2017 144" Wheel base, blue grey, 4x4, Sprinter Van. The van currently has 12,000 miles on the odometer. The price is $108,000. The van is located in Los Angeles, CA.
Here is a list of the options and add ons..
Blue Grey
VU9 Leatherette black
AR2 Axle Ratio 3.92
CT1 Rear Spring Vibration Absorbers
C01 C01 Driver Comfort Package: 12V outlet at driver seat base. $570
SB2 : Comfort Passenger's Seat
SB1 : Comfort Driver's Seat
FZ9 : Keys - Two Additional Masters
FJ1 : I/P Hinged Lid-Center Stack Bin E46 : 12V Power Outlet- Driver Seat Base
C02 C02 Driver Efficiency Package: Becker map pilot navigation $1,520 system.
MS1 : Cruise Control
L16 : Fog Lamps
FR8 : Rear View Camera
E1N : Becker Map Pilot
C04 C04 Active Safety Plus Package w/Parktronic: Multifunction $2,680 steering
Y45 : Emergency Flash Light
Y10 : First-Aid Kit
LD0 : Overhead Cntrl Panel w/2 Lamps LA1 : High Beam Assist
JW5 : Lane Keeping Assist
JK3 : I/P Cluster Pixel Matrix
JA7 : Blind Spot Monitoring
JA6 : Collision Prevention Assist
JA5 : Light and Rain Sensor
H21 : Windshield with Filter Band
F68 : Exterior Mirror - Power/Heated
EZ8 : Parking Aid System FRT&RR
CL4 : Multifunction Steering Wheel
ED5 Parametric Special Module
EN7 Audio 15 (Standard)
HZ9 Fuel-fired heater booster (17,000 BTU) $618
H01 Heat Insulation for Rear Compartment $143
H04 Heat Insulation for Front Compartment $170
H15 Heated Co-Driver Seat $260
H16 Heated Driver Seat $260
R98 Rims painted Jet Black $74
T12 Sliding Door - Two Stage Opening $75
T85 Assist Handle-Left Rear Door $29
T86 Assist Handle - Right Rear Door $29
WD5 Control code
W73 Rear Door Step - Bumper, Gray
W78 Window rear door and washers/wipers
X27 Additional Battery Package: Additional battery for retrofit.
E36 : Cutoff Relay for Auxiliary Battery
E28 : Auxiliary Battery 100 Amp
X30 X30 Low & High Range 4x4 Package
ZG3 : 4x4 High Range w/Low Range Transfer Case
T75 : Door mounted assist handles, driver & passenger
ZH4 Downhill Speed Regulation for 4x4
Factory Roof Rails Added
FULLY LOADED
COVERSION SPECS:
Sound Deadner
Full Insulation (R13)
1/2 Maple Subfloor opped with Marine Grade Woven Vinyl
2 Fantastic Fans with rain sensors
Solid Walnut Walls & Ceiling
Solid White Oak Galley, Overhead Cabinets, Benches & Table
15 Gallon Fresh Water tank
15 Gallon Grey Water tank
Isotherm Cruise 85 Fridge
Wallas Diesel Heater/Cooktop
Deep Sink & Faucet
Magnetic Window covers throughout
12 LED touch lights
200 Watts of Solar on the roof
3000 Watt inverter
30A Shore power connection
420AH Gel Cell batteries with cage mounted under vehicle
8 Gallon hot water shower (exterior use)
RB components raised headliner shelf
Method Race wheels with 285 BFG Tires
Tinted Windows
Window Rain Guards
custom upholstered bench cushions
12 overhead storage cabinets
Storage under benches
Drawers in Galley
here are some photos
Thank you for looking
Blue Grey
AR2 Axle Ratio 3.92
L16 : Fog Lamps
Y10 : First-Aid Kit
WD5 Control code
FULLY LOADED
COVERSION SPECS:
Sound Deadner
Deep Sink & Faucet
12 LED touch lights
3000 Watt inverter
Tinted Windows
Window Rain Guards
Drawers in Galley
