Setting up Epever MPPT with Battle Born LiFePO4
skivo
If anyone is trying to setup their Battle Born LiFePO4 charging profile for their solar, these are the numbers I was able to collect from Battleborn's site.
I am using Epever 40amp solar charger Tracer-BN Series.
https://battlebornbatteries.com/shop/12v-lifepo4-deep-cycle-battery/
Probably other charge controllers are better at setting up lithium bat profiles. Mine was a #pita!
Here are the numbers. If any of them look off, please correct me if I am wrong.
Temp compensation 0
Over Volt. Disconnect 14.7v
Over Volt Reconnect 14.6v
Equalization Charging 14.4 (or blank)
Boost Charge 14.2-14.6v
Float Charge 13.6v
Boost Reconnect Charge 13.2v
Charge Limit 14.6v
Discharge Limit 10.6v
Low Volt. Disconnect 11.10v
Low Volt. Reconnect 12.0v
Under Volt Warning 11.45v
Under Volt Warn Reconnect 11.5v
Equalization Duration (leave blank)
Boost duration 30 per battery
