Old 12-03-2019, 02:21 AM   #1
Andrew_T
Default Make your old interior Sprinter look new again.
My 2008 has seen a lot of road at 440k miles.
So I decided to upgrade the old worn out steering wheel, orange backlit instrument cluster to a white light one and a proper Mercedes shifter knob...from a 2017. That’s right.
Plug and play, even the airbag buttons work.
Instrument cluster needs reprogramming.
All menu options work from the steering wheel. Installed an Xtrons 9” headunit and I can turn volume up and down from the steering wheel. No more reaching to the headunit for that.
All in all, a well worth investment if you find a wrecked 2017-2018 and they’re asking fair prices for these parts.
Makes you enjoy driving it that much more!
File Type: jpg E80E37CA-A888-4E66-A79D-5EA26D3FDFE6.jpg (100.3 KB, 265 views)
Andrew_T is offline   Reply With Quote
The Following 8 Users Say Thank You to Andrew_T For This Useful Post:
boltman (01-03-2020), CJPJ (12-03-2019), hippy (12-18-2019), JFM (12-03-2019), Mickyfin (12-03-2019), Old Crows (12-04-2019), ricracer16 (12-03-2019), synergy_58 (12-03-2019)
Old 12-03-2019, 04:22 AM   #2
synergy_58
2009 Navion and 2015 Crew
synergy_58's Avatar
Default Re: Make your old interior Sprinter look new again.
WOW! That is very cool! I'd love to up grade my head unit, and have controls on my steering wheel. That is Bad Arsch!!!
2009 Navion 24J
synergy_58 is offline   Reply With Quote
The Following User Says Thank You to synergy_58 For This Useful Post:
Andrew_T (12-03-2019)
Old 12-03-2019, 04:56 AM   #3
Andrew_T
Here’s the headunit I installed: plug and play.
https://www.amazon.com/gp/aw/d/B07X6...b_b_asin_title
The Following 2 Users Say Thank You to Andrew_T For This Useful Post:
Mickyfin (12-03-2019), synergy_58 (12-03-2019)
Old 12-03-2019, 03:48 PM   #4
Kajtek1
Did your van had originally wheel buttons?
how is the GPS working?
Kajtek1 is offline   Reply With Quote
Old 12-03-2019, 03:57 PM   #5
Andrew_T
No steering wheel buttons prior to installing this.
The plugs in the back of the steering wheel /airbag are the same.
I only used the GPS last night via google maps and it was tethered to my phone . Worked great!
I know it comes with its own maps that you can download into the unit and use it as a stand-alone device but haven’t tried that yet.
The Following User Says Thank You to Andrew_T For This Useful Post:
Kajtek1 (12-03-2019)
Old 12-03-2019, 04:30 PM   #6
jjg214
https://www.terrawagen.com/collectio...steering-wheel
Thats interesting, these guys say you cant swap a non-button wheel to a button wheel, so I always thought it wasn't possible.
jjg214 is offline   Reply With Quote
Old 12-03-2019, 04:40 PM   #7
Andrew_T
They probably can’t advertise it as a direct swap because not all steering wheel buttons will work, except the volume buttons and call/hang up buttons to the right of the steering wheel.
If you however get a newer instrument cluster as well, re-program that to your car, then sure enough, all buttons including the left side steering wheel work since you’re able to scroll through the instrument cluster menu and sub-menus just fine.
I’ve been asked in PM how much did all this cost and if anyone else is curious, around 650$ in parts and whatever your guy/dealership charges you for re-programming of the cluster.
Having said that, 2 of the sprinter dealerships in my area refused to do the work because they said it’s not gonna work.
So you just need to find a capable guy that knows his stuff around this.
Old 12-03-2019, 04:50 PM   #8
Kajtek1
Unfortunately not too many of them around the World (and I know World)
Would you mind share location of your guy?
Old 12-03-2019, 04:51 PM   #9
Andrew_T
Yes, Seattle area.
If anyone is interested I can PM his phone number.
Old 12-03-2019, 04:57 PM   #10
glasseye
glasseye's Avatar
These aftermarket head units... What happens at night? Are they easily dimmed?
