Old 07-02-2019, 08:25 AM   #31
billintomahawk
'02 2.7 T!N Freightliner
Default Re: Tank-A Re-purposed Van build - Input Appreciated
A cautionary tale.
Had to retighten every propane fitting today.
Early morning visit to Hilgy' LP. I needed the sniffer.
Got the morning crew just as they came in and Adam helped me.
Suspicions confirmed a very small leak so cabinets moved and wrenches out.
An old guy in Florida told me about gas...you tighten it tight and then you give it one extra...one extra..so give yours two for me.
Back to Electric Tim tomorrow.
bill
billintomahawk
2002 T1N Freightliner
OM 612 2.7L
Transporter 1 Neu 154HP
2500 140"WB, low top
Tank, the repurposed van
Old 07-03-2019, 04:51 AM   #32
billintomahawk
Cables.
As it turned out I only needed to shorten one cable and turn it into two.
Brother Tim was installing new batteries at the rate of 6/hour as tourists straggled in with batteries big and small for toys, boats and cars.
I grabbed my cables and flew.
Vehicle running, connected to vehicle via starter .
Disconnected
Solar panel plug
Next, string some wire...deadline looming.
bill
billintomahawk
OM 612 2.7L
Old 07-04-2019, 04:40 AM   #33
billintomahawk
The wiring is done now.
I had to go Russian to get the lights in.
Solar system at 100 watts fully functional and feeding the house battery directly. It will charge the vehicle battery in an emergenccy when switched. The house battery will start the engine should it be necessary as you can see from the wiring diagram(dead/weak vehicle battery. Solar panel is charge controlled.
That is really the beauty of this simple system. Simple but so versatile, even life saving.
For interior lights four kinds.
12V LED powered by house battery
Battery pack light over burner
AAA remote control
OEM cargo lights powered by vehicle battery
Full Sine wave inverter 600 watts will run 120V chargers/phone charger/USB.
...The control center...
Four circuits. All fused 10 Amp as yu can see.
Overhead fan
Refrigerator cooling fan
Propane alarm
House lights
bill
billintomahawk
OM 612 2.7L
Old 07-04-2019, 09:16 AM   #34
The Grand Tour
Banned
I would offer sporkrider the opportunity to re-purpose my black water tank as his drinking water tank, if he was able to scrape up enough money...
Old 07-16-2019, 03:21 PM   #35
billintomahawk
So just a follow up.
I wanted to attach this thread.
https://sprinter-source.com/forum/sh...ad.php?t=77556
Very good information on general electrical theory with excellent practical ideas on wiring and charging(and fuses).
As with all things the proof is in the use and so I find myself in Colorado having made the jump from Wisconsin to Aspen to Boulder to Fort Collins and now in Great sand Dunes National Park headed for Silver City New Mexico.
20-24 mpg and great power in the mountains with the Green Diesel Engineering tune.
All is well and the rig travels very well.
The refrigerator is wonderful, cabin lights work, the bug screen keeps the mosquito at bay.
I'll post a couple of action shots from the road.
I've kicked out a couple of codes relating to the ABS system but they aren't related to the build and I'll go after them over on the T1N talk forum.
I should add I still need a propane locker but the other issues were resolved with careful work and tight connections.
The refrigerator installation is a huge success and I love having fresh foods.
Peace brothers and sisters where ever you are and thank you for the forum.
bill in tomahawk
billintomahawk
OM 612 2.7L
Old 07-21-2019, 07:09 AM   #36
billintomahawk
Just an old tank.
bill
billintomahawk
OM 612 2.7L
Old 12-06-2019, 02:57 AM   #37
billintomahawk
OK.
More build pics
A more finished look?
Done 5k miles, maybe 7 since New Mexico.
On the road January 1, 2020
bill in tomahawk
billintomahawk
OM 612 2.7L
Old 12-06-2019, 04:25 AM   #38
markxengineering
I like the use of the wire storage baskets. I'm changing more shelves/surfaces/baskets in my van to mcmaster pn 9211T404 (stainless mesh wire cloth) instead of solid because after 1.5 years of continuous living in the van, there is a noticeable difference in the dust/dirt/funk buildup in places where I originally used the mesh vs. solid materials. Mesh allows better air movement and a more open feeling inside. It never needs cleaning, as it lets moisture and dust drip to the floor, which is getting cleaned regularly no matter what.
2006 Hi Top Window Van 140"
The Following User Says Thank You to markxengineering For This Useful Post:
billintomahawk (12-06-2019)
Old 12-06-2019, 02:58 PM   #39
billintomahawk
Mark,
I hope the baskets work. They were cheap and easy to install yet have lots of carrying power but travel will tell?
One thing to notice is that I took a piece of the old side wall rail from the cargo configuration and mounted it along the drivers side of the sleeping platform above it. I will be able to hang things like cross country skis or ? along that wall up high. I have several more pieces left over so more will probably get screwed into the ceiling ribs.
bill
billintomahawk
OM 612 2.7L
Old 12-07-2019, 04:30 AM   #40
Robert Foster
Originally Posted by billintomahawk View Post
RJV,
Rustoleum all the way.
https://www.rustoleum.com/product-ca...tective-enamel
Wheels too.
Very little prep.
Washed with detergent and well rinsed, may have used a sponge mop to get up high.
Only use this Rustoleum enamel. Do not use the acrylics, they dry to fast to level well.
Tape with this, it's expensive but very worth it.
https://www.target.com/p/frog-tape-1...E&gclsrc=aw.ds
Use a good brush.
2 1/2 inch or so.
Do it once, don't go back. Do a second coat, it will go fast.
Shade and no wind are your friends.
bill
I am inspired by this info for my own refitting. I have closely looked at every picture in this thread and am amazed at the quality of your paint job that was done with BRUSH. I think my dream of a desert tan Sprinter Westfalia with a white roof may just have become a reality with Rustoleum Enamel.
PS. Love the woodstove too...nothing makes a place feel more like a "home" than a hearth
2005 Sprinter Westfalia ... currently undergoing a complete refitting
