Go Back   Sprinter-Forum > Regional Discussions > USA
Old 06-03-2019, 10:38 PM   #1
Youngdotpark
Default D+ signal wire
Greetings,
I need to run D+ Wire to my Battery Charger from 2017 Sprinter 3500 in order to make this battery charger to work. Do anyone has a picture and location information where I can run my wire from Sprinter to a Renogy DC - DC Battery Charger? Actual Charging unit is not ON unless I plug a cable from D+ relay. Last I heard that it was under the driver seat. I'd like to see the picture of that location and a possible instruction to run a wire to this charger to charge a house battery.
Thank you,
Youngdotpark is offline   Reply With Quote
Old 06-03-2019, 11:03 PM   #2
Youngdotpark
Default Re: D+ signal wire
If I don't find a way to run a wire from Sprinter Van to Renogy Dc to Dc battery Charger, I may have to go buy one Battery Isolator to replace Renogy Battery charger. In that case, anyone can recommend a good Battery Isolator for 2017 Sprinter Van?
Appreciate the help.
Old 06-03-2019, 11:28 PM   #3
Cheyenne
UK 2004 T1N 313CDi
Cheyenne's Avatar
Originally Posted by Youngdotpark View Post
Greetings,
Thank you,
You need to look for your EK1 terminal block under the drivers seat. If you search the NCV3 sub-forum for 'EK1' you should find photos and descriptions of where it is.
Keith.
Edit. Look at post 3 in this thread... https://sprinter-source.com/forum/sh...&highlight=EK1
36,000 miles from New
Old 06-03-2019, 11:35 PM   #4
Youngdotpark
Thank you very much.
