boxer rebellion
Hello All,
did the EGR cleaning a 2006 Sprinter 158' passenger. See pics, fairly simple, removal was easy, thank goodness the EGR was not stuck with too much carbon build-up. I only encountered 1 issue. The bolt that is closest to the coolant hose was difficult to re-installed after cleaning, not sure why, it is probably too short. I also replaced with NEW EGR gasket.
for the bolt replacement, I went to Home Depot and found a M6 - 1.0 bolt in the metric hardware fastener section. I tried to look for Stainless Steel bolt, but did not find any, so settled for Zinc plated.
Hope this will help out some if you are doing an EGR clean
Boxer
Boxer
